Cat Change corrosion issues
Old Apr 24, 2011
Myke105's Avatar
Myke105 is an unknown quantity at this point
Smile Cat Change corrosion issues
Hey I found how to change my cat and its just changing bolts and fitting the pieces but what do I do when the bolts behind the Cat are all corroded/rusted. any opinions would help
Old Apr 24, 2011
SpeedDownZone's Avatar
Re: Cat Change corrosion issues
Alot of wd40 I guess. But I changed mines not to long ago and they where the same and eventually broke. Had to buy new one from local auto zone.
Old Apr 24, 2011
Myke105's Avatar
To prepare for that when i go there what size bolts would i buy?
Old Apr 24, 2011
lazlong's Avatar
If penetrating oil and a hammer won't do it then your gonna have to cut them off. Bolts are special. You need bolts, springs, and gaskets. You can order them here: http://www.hondapartscheap.com/southbay/jsp/home.jsp Look under your model then under "exhaust pipe".
Old Apr 24, 2011
he's got an EX, so they're just regular bolts and nuts sitting behind the cat.
I forgot what size, but I'm rocking the grade 10.9 **** they have at autozone holding my downpipe and midpipe together.
Old Apr 24, 2011
lazlong's Avatar
Sorry, wasn't paying attention. Didn't see "behind".
Old Apr 24, 2011
I used this Name:  IMAG0192.jpg
Old Apr 24, 2011
As long as they're long enough to penetrate through the 2 flanges and the nut, you'll be fine. That, and the diameter seems fitting for the exhaust.
M10x1.25 sounds like what I used also.
Old Apr 24, 2011
Myke105's Avatar
Thank you so much guys
Old Apr 24, 2011
No prob and thank smart phones that take pic upload them and post them in less than a minute possible. Haha
docmartin14
Jul 30, 2015 11:26 AM
markp94
Apr 30, 2015 09:19 PM
kevin99ek
Apr 23, 2015 09:32 PM
CaptainAmerica
Dec 31, 2001 04:41 PM
colombianDXcivic
Bolt-on Engine Performance
Nov 22, 2001 03:17 PM
