Something is rattling
Old Apr 9, 2011
leelasheller882's Avatar
leelasheller882 is an unknown quantity at this point
Unhappy Something is rattling
I have a 2002 honda civic sedan. It doesnt happen all the time, but sometimes when I reach speeds between 35-45 mph and my foot rests on the gas pedal at that speed, something rattles. It feels like it is on the passenger side of the car and as soon as I take my foot off the gas pedal or change my speed it stops. It happens often enough that I want to make sure its nothing serious. Any idea as to what it could be?
Old Apr 9, 2011
Kennykid2002's Avatar
Kenny the Ricer
Re: Something is rattling
Might be something in your suspension,
I would remove the wheel and check if anything is leaking/torn/broken
Old Apr 9, 2011
MelJ's Avatar
Trance Addict
Check your exhaust as well. Might be a hanger or something. My car had a similar issue when the resonator started to go. It was accompanied by a deep bass underneath the car though......
Old Apr 10, 2011
Manwer's Avatar
Manwer is an unknown quantity at this point
I'm a very new member and I have 2005 Civic Lx. This happend to me last week and I took it to a work shop. The guy 1st replaced the breaks and the noice was still there. Then he replaced the Hub bearings on the passenger side and the noice went away. He didn't change the driver's side and said if there is a need we can do it later.
I found the following from one of the web pages:
The most common symptom for HONDA Civic hub bearing failure is noise. This is a humming noise that changes pitch with the speed of the vehicle and may also come and go as you turn left or right. Unevenly worn tires and some road surfaces can cause similar noises.
Hope this helps.
Old Apr 10, 2011
Thanks everyone! Ill have to take it back to the service center and suggest these!
Old Apr 10, 2011
and please post on the right section next time - you posted on the 2012 civic forum - not really your year model, i would guess...
Old Apr 14, 2011
JapSir's Avatar
Nothing Sounds As Good As VTEC
JapSir is an unknown quantity at this point
Could be something as simple as a heat shield underneath the car but chances are if u needed a bearing on one side u might on the other, if it is the bearing it should snd like a whizzing noise getting louder the faster u go and not really a rattling ! :/
On the other hand it could be a number of things ie track rod end,springs ect
mistahlorax13
21
Nov 18, 2015 12:47 PM
rovafa2002
Sep 28, 2015 06:57 PM
fvckbg
Sep 8, 2015 09:55 PM
dantheman42
Sep 4, 2015 01:10 PM
Yazan93
Jul 14, 2015 08:56 PM
