Vtec malfuntion
Old Mar 14, 2011
rodburner's Avatar
rodburner is an unknown quantity at this point
Vtec malfuntion
Just finished up doing a head gasket drove about 20 mi test last night everything looked good left this morning for a long test drive cooling system looks good after 120mi drive BUT early in the drive the engine light came on and if you put your foot in it at freeway speeds the engine cuts out like it wants to die let off and everything is fine and if your driving around town and get on it it works fine no cut out, i am getting a P1259 code thats not in my book but i called a mech. i know he looked it up and its a Vtec malfuntion i have checked all the plugs they look to all be connected i'll pull the air cleaner to get a better look at things this week just thought someone may have run into these symtoms and give me a short cut if it were a forgoten plug it would have started right away i would think
Old Mar 14, 2011
Re: Vtec malfuntion
make sure oil is full, also may want to take the vtec solenoid apart and clean the filter screen.
Old Mar 15, 2011
rodburner's Avatar
Re: Vtec malfuntion
Thanks gear i'll give that a shot this week, oil is good i would think the screen should be clean the shop i took it to cleaned up the head real nice but they did take that unit off and i did'nt pay much mind to it i just re-installed it so i'll take it off and have a look
Old Apr 18, 2011
JBS36606's Avatar
JBS36606 is an unknown quantity at this point
Re: Vtec malfuntion
Rodburner - Did you find anything? As of today I have the same situation.
Old Apr 18, 2011
Kennykid2002's Avatar
Kenny the Ricer
Re: Vtec malfuntion
You can pretty much only get VTEC malfunction if your filter screen is clogged up, or you have dirty oil going into it
Old Apr 19, 2011
jaylo600's Avatar
jaylo600 will become famous soon enough
Re: Vtec malfuntion
Hi i'm a newbie here so pls go easy. My 02 si is doing this exact same thing in any gear. If I get close the 4k rpm she bucks like crazy. My oil level is good , I know there is an oil sensor switch of sorts that is related to the v-tec system some how but I'm not sure how it works.
Old Apr 19, 2011
Re: Vtec malfuntion
any engine light? the oil pressure sensor has its own code if its bad. you can take the solenoid off and dismantle it. clean the filter screen gently with a lint free cloth and flush any particles out with oil. spray carb cleaner to the actual solenoid and then reoil it once dry. put it back together and if it still causes problems, the solenoid is bad/sticking and needs to be replaced.
Old Apr 19, 2011
jaylo600's Avatar
Re: Vtec malfuntion
Ok thanks I'll give that a try a post my results. Btw yes my check engine light is on (along with my srs and low wash fluid even though it's full ) I scanned it and came up with a code P1259 wich seems to be the solenoid. Dumb question but is the solenoid located drivers side facing the firewall ?
Old Apr 19, 2011
Re: Vtec malfuntion
on 01-05 its more on the back passenger side. check this thread there are pics somewhere in the first post.
https://www.civicforums.com/forums/1...e-up-mods.html
Old Apr 26, 2011
jaylo600's Avatar
Re: Vtec malfuntion
Okay, I said I would post my results because I hate newbies that join a forum get the answer and then don't post results for otheres to learn from, so here we go. I took the v-tec solenoid apart and cleaned out the filter (it wasn't that bad) , removed the egr and cleaned it out too (again not really dirty) finally I did an oil change. As I watched the amount of oil hit the pan, I answered my own question: the reason I was having problems was because there wasn't enough oil to properly open/activate the solenoid switch for the v-tec to operate properly. I feel like a total goof but sometimes we need to learn the hard way. Speaking of learning the hard way, if anyone is removing thier egr be careful not the break the tip off of the temperature sending sensor that is located right beside it. Ya you guessed I broke mine ($30.00 later). Conclusion , my Civic runs great once again but I am concerned about the oil consumption issue.
Old Apr 26, 2011
Re: Vtec malfuntion
for oil consumption, try an auto-rx.com treatment and then switch to a hi mileage oil like valvoline maxlife. and switch up to 5w30 if youre using 5w20.
Old Apr 26, 2011
Re: Vtec malfuntion
jaylo600,
props for coming back to report - Thumbs-up
Old Apr 27, 2011
jaylo600's Avatar
Re: Vtec malfuntion
Been using 5w 20 full synthetic with Lucas in all my vehicles, never had any problems before but I will give the 5 30 a try next time.
Elciteeve
Sep 28, 2015 12:40 PM
Dave Brabant
Sep 27, 2015 09:43 PM
beanhead
Sep 24, 2015 12:04 PM
chiquita.banana
Sep 24, 2015 09:42 AM
Dave Brabant
Sep 12, 2015 08:39 PM
