Want Start
Want Start
02 Civic LX just shut off when backing, it will turn over, but not crank, I checked the timing marks with #1 @ TDC, it's OK, I checked the plug wires for firing and there is no fire, could ALL of the ignition coils be shorted out or is there something that could have come loose or shorted out the would keep the ignition coils from firing?
Re: Want Start
I deleted your other thread because it was the same as this one and in the wrong subforum. Check your fuses, it's not likely that all your coils would go at the same time. How did you check for spark?
Re: Want Start
Check your spelling too. Title fail.
You need to check your spark plugs, if those are good, then check your coil packs, keep moving up the chain till you hit the battery. I'd start off by checking the fuses, that would explain all the coil packs not working.
Wild Cranker
427
Jan 28, 2016 06:49 PM
SSMatey
Apr 13, 2015 06:09 PM
black2k1vtec
Dec 6, 2001 09:49 PM
