Suspension Question?
Old Jan 18, 2011
donman's Avatar
donman is an unknown quantity at this point
Hey, I have a 2002 Civic coupe and it has 183,000 miles on it. I took it a shop and they told me that I'm going to need new struts. The total cost for parts and labor is around $800.00. I was always thinking of lowering my car,
If i lower my car would it be cheaper then to buy OEM parts or do i still have to buy OEM parts plus other stuff to get the car lowered?
Old Jan 18, 2011
Kennykid2002's Avatar
Kenny the Ricer
Re: Suspension Question?
if you're going to spend $800 on replacing them, might as well lower it yourself with new struts, springs and camber
completely up to you though, springs only have a set amount of drop, so they arent changeable to your liking
Old Jan 18, 2011
donman's Avatar
How much do you think will cost to drop it. Just a little bit. I don't even want the wheels to tuck. Are there any kits that you know of? Or any websites?
Old Jan 18, 2011
MindBomber's Avatar
Live for the Twisties
Tokico hp struts, tein s.tech lowering springs and a good quality camber kit like ingalls or spc will be around $700, that would be a complete set-up for lowering you car. You would still need to change out and components that have weakened over time like ball joints, tie rod ends and LCA bushings because a lowered car is hard on its suspension.
Old Jan 18, 2011
donman's Avatar
Tokico hp struts, tein s.tech lowering springs and a good quality camber kit like ingalls or spc will be around $700, but that would be a complete set-up for lowering you car. You would still need to change out and components that have weakened over time like ball joints, tie rod ends and LCA bushings because a lowered car is hard on its suspension.
Thanks...
Old Jan 18, 2011
you can also look at eibach springs.
or coilovers, but they will be more expensive (skunk2, tein, D2, etc, etc.)
EdGasket
40
Nov 27, 2015 11:11 AM
civic98?
Aug 13, 2015 01:32 AM
Strycker
Aug 2, 2015 08:40 PM
JKWood
Jul 28, 2015 03:45 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
