Water Pump + Timing Belt
Old Nov 20, 2010
NotoriousMohsin's Avatar
NotoriousMohsin is an unknown quantity at this point
I recently purchased a 2002 Honda Civic Sedan.
I bought it with 180km and now has approx. 220km
I would like to know how do i know if the water pump and timing belt has already been changed..and i would like to know how many times do i have to do it?
Also what can i do to this car to make it better..performance wise, luxury wise..or anything that just adds a better look i guess.
I currently have HID lights a regular cd deck and subs.
Any Suggestions?
Old Nov 20, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: Water Pump + Timing Belt
General rule of thumb is timing belt and water pump every 100k miles. So, even if it has been done your due up. How many times you have to do it depends on how long the car lasts. If the car goes to 550k, you have to do it 5 times
Performance wise, stick to suspension. Do a bit of search and you will find a ton of mods you can do to your civic to improve it. Unfortunatly, unless you plan on spending a lot of money on it, it won't go any faster.
Old Nov 20, 2010
Kennykid2002's Avatar
Kenny the Ricer
To be on the safe side, I would either replace the timing belt myself, or have it checked out at a shop, and replace all the fluids.
You never can be sure when the previous owner did maintenance unless he has scheduled maintenance done at a dealer, or certified shop, and has all the paperwork
because 1, you dont know the quality of the job done
2, you dont know what fluids/materials are in the car
there are minor mods to make your car slightly better fuel efficient, and some to add minor performance, but like tbohar said, dont expect it to be a M3 without dropping the value of the car itself on it.
There are also mods like bumper lip kits that will make your car look better
Old Nov 21, 2010
do you mean 180,000 and 220,000 KM?
BTW, tbohar, he said KM, so he is due once only. he is about 135k miles. If he means 220k KM, of course
Don't recall an easy way to spot if work has been done...
Did you have any vin checks, maintenance records, etc?
sharp66
31
Jun 12, 2022 08:45 AM
mattdoc
Mar 14, 2017 12:10 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
CivicVoz
Apr 16, 2015 08:07 PM
dano2005
Apr 14, 2015 01:58 AM
