Problem with AC light staying on
Old Oct 19, 2010
Mr.X's Avatar
Mr.X is an unknown quantity at this point
Arrow Problem with AC light staying on
I have a 2001 Honda Civic Si, I bought the car recently. Has 220,000 KM on it and Works fine. However the button to turn the AC on doesn't work properly. Often times it will remain on when I did not turn it on and sometimes when trying to turn off the AC it remains on and refuses to turn off.
Please post any solutions you can think of to help me fix this problem. Everything helps,
Thanks.
Old Oct 19, 2010
Mr.X's Avatar
Re: Problem with AC light staying on
Also I have tried taking it apart before but not exactly sure what to look for to solve the problem.
Old Oct 19, 2010
CraigW's Avatar
Are you in either the floor/defrost or defrost mode when the light stays on ??
There is a procedure here to allow the A/C button to be pressed when the light comes on and release the compressor.
Old Oct 20, 2010
dustysaw's Avatar
dustysaw is an unknown quantity at this point
There is something you can do to change that?? I thought it was just stupid engineering on honda's part, where the a/c cant be turned off when the defrost modes are on...
Old Oct 21, 2010
lazlong's Avatar
Do you have a multimeter (DMM)? Can't properly diagnose without one. In the meantime, check for blown fuse 14 in the under-dash fuse/relay box and loose connections at the control panel and ground G502-
#13:
Service manual says it can only be a loose connection, the control panel, or the motor. Get a DMM and you can diagnose instead of spending money just replacing things.
Old Oct 21, 2010
CraigW's Avatar
https://www.civicforums.com/forums/7...rost-mode.html
Anytime you go into floor/def or def from another setting the compressor and A/C light will come back on. After you do the DIY you will be able to push the A/C button and release the compressor.
Old Oct 31, 2010
MoreRicePlease's Avatar
MoreRicePlease has a spectacular aura aboutMoreRicePlease has a spectacular aura aboutMoreRicePlease has a spectacular aura about
Yeah, man. That's the way they made it. There's no problem with it. If you have an owners manual, you should skim through it; you can learn a ton about your car.
mikemc422
Aug 9, 2018 05:41 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
Ma213802
May 18, 2015 07:01 AM
werdnahall
May 17, 2015 11:37 AM
blackbullet
Dec 1, 2001 03:44 PM
