Air Filter box screws
Old Oct 6, 2010
aroyale15's Avatar
aroyale15 is an unknown quantity at this point
Does anyone have any issue with the screws that attach the air filter cover. I have 3 screws that have been stripped so far.
Also is there a cheap place I can get a replace. Thanks
Old Oct 6, 2010
lazlong's Avatar
Re: Air Filter box screws
VERY common problem with these models. The heat eventually makes the plastic brittle. Probably have to get another airbox or time to get a CAI. For parts: https://www.civicforums.com/forums/8...ml#post4492545
Old Oct 6, 2010
02civicsi02's Avatar
Low and slow!
Go buy a tap and dye set and re thread all the threads.
Old Oct 6, 2010
lazlong's Avatar
It's not really the thread so much that the metal "sleeves" the threads are in that turns in the plastic housing. And there's no way to get it to catch from the back. I finally had take my drill, put it on the highest speed, and spin it and push until it came out the back. I wasn't about to leave a $40 filter in there.
Old Oct 6, 2010
the problem is its cracked, not stripped. just get a new airbox on ebay and only tighten the screws hand-tight with screwdriver (not socket wrench). its caused by overtightening most of the time tho, not really heat. screws in plastic need to be torqued very carefully.
Old Oct 7, 2010
CraigW's Avatar
The bottom end of the threaded inserts are open allowing corrosion to form and lock the 2 together. I kept my captive screws lubed with a very light oil, it helps prevent from breaking.
Old Aug 9, 2011
thwipp89's Avatar
thwipp89 is an unknown quantity at this point
so...if we have this problem ("stripped air filter cover screws"), do we need to replace the air filter cover, the screws...or both? are replacement covers any better or do we just have to hand tighten the screws and be careful? thx!
Old Aug 9, 2011
lazlong's Avatar
You shouldn't have to get new screws unless you can't get them out.
Old Aug 10, 2011
CraigW's Avatar
The biggest worry would be if you were to break the plastic housing holding the metal inserts that the screws thread into imo.
vtecbrah
May 12, 2015 01:30 PM
carid
Apr 30, 2015 07:00 AM
joe
Dec 10, 2001 10:33 AM
