Cluster Swap Gone Bad
Old Oct 5, 2010
speedycivic05's Avatar
speedycivic05 is an unknown quantity at this point
I was swapping out my old 05 VP speedometer for a 04 Lx speedometer and ran into a problem. After re-pinning everything (double checked), I turned everything on to find out that the radio does not work. I find this strange. Are the pins for the cluster related at all to the radio? If so, does anyone know which pin (color/pattern) I should look for to solve this problem? Also, my gas needle tells me I'm running empty and my dome light doesn't work on the 'door' option.
A side question- There's only supposed to be 1 wire (white-red from Green adapter) that doesn't need to be pinned, right?
Any help would be appreciated!
Old Oct 5, 2010
lazlong's Avatar
Re: Cluster Swap Gone Bad
Pinout shows no radio wire. Sounds like you blew the Multiplex control unit. Did you disconnect the battery before you began work?
Old Oct 5, 2010
I thought it had no relation. And no, I did not disconnect the battery. If it is the Multiplex unit, how do I go about repairing that?
Old Oct 5, 2010
CraigW's Avatar
Check "back up" in under hood box.
Old Oct 5, 2010
wow i normally never disconnect the battery for any work, but the cluster swap is the one time you really have to. there are live wires and its very easy to short something out. hopefully its just a fuse. and when you say the radio doesnt work, do you mean it doesnt light up? or that it does not turn on and play music.
Old Oct 6, 2010
The radio simply doesn't turn on anymore. I don't see my clock either. It's completely off =/
Thanks for the help, everybody =) Hopefully, it's just the fuse ><
Old Oct 15, 2010
FINALLY got the radio working again!!! Turns out, that it WAS just a blown fuse. It was the 'back up' fuse under the hood. Thanks for all the help guys!!!
Old Oct 16, 2010
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
consider your self lucky that it wasent somting else.
Old Oct 16, 2010
Kennykid2002's Avatar
Kenny the Ricer
Very lucky, next time, anything electrical, DC the BATTERY
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
youngm
Jun 4, 2015 10:19 PM
jimmyfloyd
May 20, 2015 07:06 PM
Ma213802
May 18, 2015 07:01 AM
One_PeeJay
May 17, 2015 05:31 PM
