7th gen trunk pop solenoid mechanism
Old Jul 11, 2010
gatrhumpy's Avatar
gatrhumpy is an unknown quantity at this point
My wife has a 2003 Honda Civic with a Python 460HP alarm system installed, and it has a two button keyfob, including an aux feature. Is it possible to get a solenoid trunk popper mechanism installed in this car? Tried to talk with BB and they said I need a solenoid, so where can I get this solenoid?
Old Jul 11, 2010
Re: 7th gen trunk pop solenoid mechanism
just buy the whole latch assembly from the 2001 accord. its a direct bolt-on and then you hook the wire up to your alarm. theres even a diy for it somewhere here
https://www.civicforums.com/forums/1...gen-civic.html
Old Jul 11, 2010
nmastereal's Avatar
nmastereal is an unknown quantity at this point
lmao, theres a diy here somewhere (that gear box did but doesnt want to say he did right away)
Old Jul 11, 2010
no that wasnt mine but thanks. someone else posted that a long time ago and i just reposted with the pic links fixed. its a great upgrade. ive been enjoying mine for many years.
Old Jul 12, 2010
gatrhumpy's Avatar
Gearbox, you really do know your stuff. Thanks man. Now I just have to find one of those solenoid mechanisms!
Also, do you know if the aftermarket alarm system that I have is able to be hooked up to this solenoid trunk popper mechanism from Honda?
Old Jul 12, 2010
gatrhumpy's Avatar
Gearbox, found this link to the wiring diagram for the relay. The second diagram I guess is the correct one, right? Could I find a relay like this at Radioshack?
http://www.the12volt.com/relays/page1.asp
What do the fused +12V wires (red wires in the diagram) hook up to?
Old Jul 12, 2010
gatrhumpy's Avatar
http://www.hondaautomotiveparts.com/...gry5=TRUNK+LID
Is #12 what I need (on diagram towards bottom left)? #11 looks similar, but it's not available on the website as being able to be purchased.
Old Jul 12, 2010
i dont know the specifics of the alarm wiring and what it hooks up to, i actually had circuit city install mine for $40 a while back. almost every alarm has extra channels to hook accessories to so you should be fine. and the install shop should know if the alarm uses a + or a - switched circuit. that determines whether or not a relay is required. i think 12 is the right part. can always call and ask the dealership too.
Old Jul 13, 2010
gatrhumpy's Avatar
So Gearbox, is the above part what I need for the solenoid from a 2001 Honda Accord? Part #12?
Old Jul 13, 2010
12 looks right, since it says power. i think the other part that doesnt show up is manual. all of us got ours from handaaccessories.com but im not sure they still have it or which section to look under.
Old Jul 13, 2010
CraigW's Avatar
This is the part # I got from Suzy Q a while back.
part # 08E49-S84-101H
(Trunk Opener - Accord 4D)
It has the glow in the dark release.
Old Jul 14, 2010
gatrhumpy's Avatar
Thanks guys. I will then have to get the part and install it. Anyone know where I can find the installation manual for the Python 460HP? I need to know what wire to hook up to a relay (and even if it's needed)...
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
mohawkboom
67
Aug 25, 2015 12:28 AM
Hiryuu
Jun 6, 2015 03:00 PM
Youshoe
May 22, 2015 09:36 PM
DaveyD
Mar 28, 2003 12:28 AM
