D17 Replacement
D17 Replacement
I don't know a ton about swapping engines in our civics. I have a 2001 that is having major engine issues and want to replace it. 1) Needs frequent valve adjustments (from TB problem below), every 5k miles before the CEL comes on because the valves in #3 aren't closing all the way. Tappets are backed out really far now, kind of scares me. 2) Busted timing belt a couple of years ago, shortly after a bad rattle developed from the crankshaft journal bearings. The mechanic that did the work said they weren't that bad and polished the journal and replaced the bearings, problem solved. It's now 2 years later and the problem is back.
My question is, I am looking online (mostly local classifieds to avoid costly freight of shipping those things) for a replacement and have a question or 2. I have done a lot of the work on this car myself, valve adjustments, replaced alt., Replaced Ex Mani, wheel bearings, struts, etc.. I am pretty good mechanically. How much work is involved in swapping the engine? Can they be removed out the top (I read in the service guide they are to be dropped after the subframe is removed)? Also, I don't have money for a K20, etc. otherwise I would buy a new car. But is it difficult to put an EX engine in when it is an LX? is that even worth it? Thanks in advance.
Utahbmxer
2001 LX 1.7 5spd
TCS Exhaust
AEM Intake
Utahbmxer
2001 LX 1.7 5spd
TCS Exhaust
AEM Intake
Re: D17 Replacement
i'm going to assume that you can pull the motor out the top. Swapping motors is easy if its a direct replacement (from d17 to d17 again), It's just time consuming and prep work. remove as much as possible and mark all the bolts in baggies and with tape so you don't forget where they go. just a tip.
Re: D17 Replacement
What about changing out from LX to a VTEC engine from an EX? Would I have to change the ECU as well? The exhaust would probably have to be redone as well right, since the NON-VTECH has the CAT built into the manifold?
Thanks
Thanks
Re: D17 Replacement
Shop Manual says motor comes out the bottom. You might have to pull the tranny to get it out through the top. I'm not completely sure though as I've never done it
Re: D17 Replacement
yah i just did a swap on my car a couple weeks ago. its not that hard if you have a four point hoist. if you dont then you can just jack up you car high enough to drop the tranny then pull the engine out the top. youll need a new ecu ( new $700, used anywhere between $40-$300), new engine harness for your type tranny and for an ex or si(canadian), header back exhaust, and some TLC. you can get the engine harness of an aqura el also, its the same engine.
Re: D17 Replacement
People do lx to ex exhaust swaps so why would you not be able to put the lx manifold on the ex motor? You should be able to pull the trans out the top followed by the engine.
Re: D17 Replacement
trust me, it is way more work to pull the tranny out the top, and im not even sure if it would fit. just go out the bottom or your probably going to run into more problems then you should have to.
Pistol grip pump in my lap at all times
Re: D17 Replacement
I personally pulled the engine out from the top. Me and my buddy unbolted the tranny, moved it off to the side a bit, and pulled it right out.
thesushiboy
Apr 12, 2015 02:54 AM
2k2civicballer
25
Feb 7, 2002 12:22 PM
SLeePeR012
Jan 7, 2002 12:24 AM
my2k1vic
Nov 29, 2001 10:29 PM
