Replacing the stock tweeters?
Old Jan 30, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
Is it possible to replace the stock tweeters with better ones? Has anyone done it? and If so...how well do they fit ? Im just curious, thanks =)[IMG]i/expressions/beer_yum.gif[/IMG]
Old Jan 30, 2002
zackde's Avatar
zackde is an unknown quantity at this point
tweeters??........u mean ur buying a stock or u have a stock tweeter installed??
Old Jan 30, 2002
HaRdKoRePinoYrAcer's Avatar
HaRdKoRePinoYrAcer is an unknown quantity at this point
why get tweeters when u can get bass!...just my opinion
Old Jan 30, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
i agree with HaRdKoRePinoYrAce, unless u already have subs
Old Jan 30, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
hes talking about the little speakers mounted near the side mirrors but on the inside in the ex coupe
Old Jan 30, 2002
GTekCiViC's Avatar
GTekCiViC is an unknown quantity at this point
yea u can replace ur stock tweeters, just take out ur door panels and than ur
tweeter holder and replace it with the new tweeters...
I have bass i need highs that's why i need tweeters
Old Jan 31, 2002
sorphin's Avatar
sorphin is an unknown quantity at this point
finding some that fit is a pita.. i hoped my infinity tweets from my 600CS would fit, but they don't.. turns out the ones from the 605CS (newer) just might tho, and you can get them seperate from the component set they're 105's..
-ds
Old Jan 31, 2002
mohawkboom's Avatar
If thr tweets do not fit.. you could always shave the hole bigger and use the mounting hardware tha came with the tweeters instead of using the stock mounting hardware..
Cheers
Mohawk
Old Jan 31, 2002
Voiceofid's Avatar
End Bringer
i swapped out the old ones from the door, i purhcased the Rockford Fosgate Fanatic X kit comes with 2 new tweeters and 2 6 1/2 , they all fit in perfect
Old Jan 31, 2002
GoCivicRacerGo's Avatar
GoCivicRacerGo is an unknown quantity at this point
I replaced my stock tweeters with Polk Audio EX3's. They are mounted in the EX tweeter pods. The Stock ones have a screw running right into the center of the magnet to hold them in, the EX3's don't. To fix this, i ran some Loctite around the edge of the tweeter pod and glued them in. Now it works and sounds great, much better than stock. Hope this helps.
Old Jan 31, 2002
thanks everyone. and yes,. i am talking about the little speakers in the doors that get the high notes. i am looking at Pioneer TS-T110 tweets from crutchfield. im perty sure theyll fit, anyone know for sure though?
Old Jan 31, 2002
mikalem's Avatar
mikalem is on a distinguished road
I'm curious to know, what's the size of the stock tweeter? Any one that's replaced them could measure that would be great!
Old Jan 31, 2002
mikalem's Avatar
Also, in case anyone is curious - Crutchfield just dropped the price on their Kenwood Z828 headunit (CD/MP3 playback) from 619 to 400 bucks. Just an FYI [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 1, 2002
nongv's Avatar
nongv is an unknown quantity at this point
what tweeter? my ex doesn't have any stock tweeter inside my car. i have a 2001 sedan ex. if there is some where can i get it?
Old Feb 1, 2002
zackde's Avatar
nong.........
i got an ex sedan also, instead adding a tweetwer much better to get a component, it will sound great i got the cheapest (with quality) component which is blaupunkt pcc1650, look at yahoo shopping u can get one for 50-60 bucks, sounds great on mine......
keep on ridin[IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old Feb 1, 2002
for you with sedans i dont think you have tweeters. and you cant replace the tweeters wtih components...you must have no idea what we are talking about. we are talkign about the mini speakers located inside your front doors right next to your mirrors...
Old Feb 1, 2002
CIVIC9782's Avatar
CIVIC9782 is an unknown quantity at this point
I replaced my factory tweeters with infinity. they sound great.
Old Feb 1, 2002
Todd1's Avatar
Todd1 is an unknown quantity at this point
come on now u have to have tweets, basss is good but the tweets make the crystal clear sound!!!!!
Old Feb 2, 2002
tsunamisplash's Avatar
tsunamisplash is an unknown quantity at this point
it you don't have the highs and lows everything sounds muddy and mixed together... gotta get good quality tweeters and subwoofers.. not to mention getting good speakers for mids.. which would of course be your 6.5's or 6x9's.
Old Feb 2, 2002
zackde's Avatar
tsunami....
dont put too much hi's in the rear for a proper REAR FILL, a decent decent set-up (i think according to my readings & experience) would be a seperates on frotn & coax on rears
HAPPY UPGRADE DUDES
Old Feb 4, 2002
Rebew1's Avatar
Rebew1 is an unknown quantity at this point
I believe the stock tweeter is 3/4" and that is what Crutchfield recommends. I have the MB Quart QM 218.61 with a 1" tweet. It fits but I need to figure out how to get the Screen on. Won't fit with Stock location. May need to do some cutting.
Old Feb 5, 2002
sorphin's Avatar
<< If thr tweets do not fit.. you could always shave the hole bigger and use the mounting hardware tha came with the tweeters instead of using the stock mounting hardware..
Cheers
Mohawk
one lil hitch is those triangular mounts don't really allow for hole resizing.. and if i mounted w/ something else, i'd need somehting to cover that area since that's where the mirror mounts [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Feb 7, 2002
slikor's Avatar
slikor is an unknown quantity at this point
so the tweeter size req'd to fit in the stock EX tweeter pods is 1"? that is the size the Polk EX3's tweeters are, and that is the size of the tweeters in the Infinity Component 6.5" setup i want, but i want to be sure the tweets will fit?? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 7, 2002
Rebew1's Avatar
A 1" will fit, no worries with that. Some tweeters come with the grill on them already so you won't need to mess with that. My Quarts however do not. I need the mounting hardware to use the grill, but it doesn't fit flush with the tweeter mount on the mirror. I just purchased new mirror garnish(tweeter pod) from Honda and I will be playing with that to make it fit. They run $4.76 a piece from Majestic Honda. I didn't want to cut the existing one in case I ever want to sell the car and keep my audio system.
Old Feb 7, 2002
slikor's Avatar
hmmm...could you just use the grill on the stock tweeters?
Old Feb 7, 2002
sorphin's Avatar
<< so the tweeter size req'd to fit in the stock EX tweeter pods is 1"? that is the size the Polk EX3's tweeters are, and that is the size of the tweeters in the Infinity Component 6.5" setup i want, but i want to be sure the tweets will fit?? [IMG]i/expressions/face-icon-small-confused.gif[/IMG] >>
the tweets from the newer gen infinity should fit or so they appear (in the circuit city backboard they look small enough).. i however have a 600CS not a 605CS.. the tweeters in mine are physically bigger they have their own surface mount "enclosure" as part of the body.. so that makes it bigger... when i get the spare $ (just bought headers, etc), gonna get the 105T's (the tweets that are in the 605CS) that you can buy seperate... justcarspeakers.com has em for $74 for the pair
-ds
CivicVoz
Apr 16, 2015 08:07 PM
silverdevil
Dec 15, 2001 06:33 PM
deception420
Dec 6, 2001 02:31 PM
mwwhonda
Dec 5, 2001 10:52 AM
ademarco6
Nov 16, 2001 10:19 PM
