Replacing headlight column switch 02 ex
Old Feb 25, 2010
triplej's Avatar
triplej is an unknown quantity at this point
My high beams don’t work, I posted this problem a while ago. I now figure the combination headlight switch in the steering column is the culprit, but really have no way of testing this theory other than replacing the switch. The parts guy at the dealer tells be they sell a lot of these switches so this reinforces my belief the switch is faulty.
Yea I’ve checked everything else, it all leads to the switch.
So, for $90 the dealer will definitively diagnose the problem, or I can just buy the switch for $55 and replace it myself.
How hard is it get at the switch? My shop manual really doesn’t offer much help..
Thanks,
Old Feb 25, 2010
CraigW's Avatar
Re: Replacing headlight column switch 02 ex
Not sure if I saw, or contributed to your other post or not ??
I'm guessing you have tried the bulbs ??
You could try grounding the RED/BLU at pin 4 of the headlight switch connector and see if the high beams come on. (it is the high beams line from the bulbs)
The switch replacement is easy except for the column covers which suck. The switch is 2 screws and 1 connector, pull switch forward.
Old Feb 25, 2010
triplej's Avatar
I did bench test the bulbs, they are fine.
Old Feb 25, 2010
TRIZ's Avatar
Download the civic manual, not the one that comes in the glovebox, the one that tells you how to take the car apart. (I'm totally at a loss for words right now if you couldnt tell)
Old Feb 25, 2010
triplej's Avatar
I have the on-line version of the shop manual, goes into some really great detail but no great when it comes to the headlights...the relay and fuses are all fine so that’s why I’m leaning toward replacing the switch.
It did get me through changing out the rear struts real fine, but in some area's it lacks detail or requires you have a degree in electrical engineering.
Old Feb 26, 2010
Awjvail's Avatar
Awjvail is an unknown quantity at this point
The steering column cover is really really really fragile. You need to be extremely careful when taking that off or else it'll snap and you'll be very sad.
Old Feb 26, 2010
CraigW's Avatar
Here is some factory info.
The column covers you remove screws fromt bottom & push in near the top and bottom seams to release latches (if your lucky)
File Type: pdf
Old Feb 27, 2010
racermp's Avatar
racermp is an unknown quantity at this point
hey, 01 and 02 civics have a recall on the combination switches, i just had mine replaced today from the dealer no charge. see if u can have them do the recall, it was for failing headlights.
Old Mar 1, 2010
triplej's Avatar
I tried that, gave them my VIN number and they said there was no recall..Must only apply to certain VIN numbers.
Old Mar 1, 2010
CraigW's Avatar
The recall only affects 01s and some early 02s.
And, is for loss of low beams only.
What about your flash option ?? Is it working ?? There are a couple methods of switching in high beams.
I would provide a quick ground to the wire I mentioned in case it is not the switch.
Old Aug 1, 2010
dzdoesit's Avatar
dzdoesit is an unknown quantity at this point
I'm having the same problem but my lights wont turn off. They stay on unless I pull the relay out. I'm hoping that changing the switch would fix this issue!
Old Nov 6, 2010
triplej's Avatar
I replaced the switch today, which fixed the problem. Broke some the tabs on the plastic top piece of the column, secured it in place with a couple drops of super glue, should hold fine... I can’t figure how you would get the column apart without breaking a couple of the tabs.
Eather way I am happy with the results!!!
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Star1967
May 3, 2015 09:09 PM
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
mwwhonda
Nov 7, 2001 07:24 PM
