Switching to the automatic headlights.
Old Apr 28, 2015
Star1967's Avatar
Star1967 will become famous soon enough
I was wondering what mods would I need to do if I switch to the auto on/off headlights used on the newer Civic models? I currently have a 2001 Civic.
Old Apr 29, 2015
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
Re: Switching to the automatic headlights.
you mean the daytime (driving) lights?
Old Apr 29, 2015
Star1967's Avatar
Yes those. What parts would I need and what years would match up to the electrical wiring of the 2001? I seen similar on a 2006 Chevy Uplander that I used to drive.
Old Apr 29, 2015
CraigW's Avatar
01 had it's own separate control module (Canada Models)
Just get in the habit of turning on your headlights, people are stupid and will still pull out regardless.
The headlight on warning will prompt you to turn them off.
Old Apr 29, 2015
drhawkinz's Avatar
read through this: https://www.civicforums.com/forums/3...problem-2.html
otherwise you would need a 12volt relay and some electrical skills.
the relay gets wired to the battery and gets spliced into the wire for the low beam headlights. then you need a trigger wire from the ignition most likely. this way when the ignition is on the lights get power from the battery and when it's off they don't have any power at all.
Old Apr 29, 2015
Star1967's Avatar
Thank you I will and CraigW thank you. I found the warning switch but it will need to be replaced.
Old Apr 30, 2015
Star1967's Avatar
Programing as in what the car's CPU or a sensor on the switch or windshield/windscreen?
Old May 2, 2015
GolNat's Avatar
Prelude Owner
If you are looking for auto on during the night you will need something like this:
AC DC 12V 10A Auto On Off Photocell Light Switch Photoswitch Light Sensor Switch - Wall Light Switches - Amazon.com AC DC 12V 10A Auto On Off Photocell Light Switch Photoswitch Light Sensor Switch - Wall Light Switches - Amazon.com
Wire that to the power that runs to the relay that powers up the lights.
Old May 3, 2015
Star1967's Avatar
Thank you I checked it out. Where would you place it so it will detect the amount of light? In the grill near the horn or on the dashboard?
Old May 3, 2015
GolNat's Avatar
Prelude Owner
I would try the grill since its a big ugly sensor that will be hard to place on the dash without cutting a hole and making it flush.
You might be able to place it in the cowl between the hood and windshield.
Old May 3, 2015
drhawkinz's Avatar
depends if oncoming headlights will turn the sensor off. i would wire it up and then shine a flash light on it to see if it turns off.
Maybe on the back dash would be better. this way it's out of the way and won't get direct light other than sunlight.
Old May 3, 2015
Star1967's Avatar
Okay good idea. Only thing is the idiots who like to tailgate.
cizsak
Jul 21, 2015 03:39 PM
Kyles24
Jul 12, 2015 09:15 PM
1khilari
Jul 9, 2015 08:12 PM
Mike_47
Transmission
Jul 8, 2015 02:42 PM
fatih717171
Jul 8, 2015 12:14 AM
