drl relay?
Old Jan 24, 2010
leosar's Avatar
leosar is an unknown quantity at this point
drl relay?
hi everybody
this is my first thread,i hope somebody can help me
i have honda civic 2003 2 doors
when starting ,light "DRL" stays flashing with noise,and front head lamp passenger side stays off,after 4-5 minutes driving ,it stop flashing and lamp come on.
the technicien told me the drl relay should be replaced,and to get it ,take time and will cost more than 100$
if somebody knows how to reach this relay please tell me,and i am able to do it myself
thanks
Old Jan 24, 2010
Re: drl relay?
should be in the manual, i think its behind the glove box. you could also have a bad drl module, alot of times the contacts need to be resoldered. module is under the dash (driver side).
Old Jan 24, 2010
CraigW's Avatar
Re: drl relay?
The connections that need resoldering are in the DRL control unit.
Old Jan 24, 2010
leosar's Avatar
Re: drl relay?
thanks
Old Jan 31, 2010
leosar's Avatar
Re: drl relay?
hi everybody
i would thank you all in this forum
i removed the light runing module (grey box under steering wheel left side)
resolder all points,now it is ok
Old Jan 31, 2010
TRIZ's Avatar
Re: drl relay?
Wow, nice work man!
Old Feb 6, 2010
incognyto's Avatar
incognyto is an unknown quantity at this point
Re: drl relay?
I took the fuse out of my fuse box that run's the drl module, I hate the fact that you can't turn the light's off after you drop the ebrake. and I need all the power I can get for the stereo hehe
Old Feb 6, 2010
Re: drl relay?
just an fyi, if you live in canada its illegal to drive without a drl. the older usa civics before 2006 did not come with this feature unless the car was sold in canada.
Old Feb 9, 2010
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
Re: drl relay?
same thing happened to my car...there are two relays in the DRL control module and all of the solder joints were cracked...i just resoldered them and the problem went away
Old Aug 18, 2010
MohsinBharucha's Avatar
MohsinBharucha is an unknown quantity at this point
Re: drl relay?
Hi im having the same problem i just bought the new gray relay module drl and i opened the dash under the steering whell their was another dash opening thingy i opened that too but for some reason i cant get hold of the drl relay i can see it and touch but is their somehting else i need to open to actually unscrew it?
Old Sep 25, 2010
cbibby's Avatar
cbibby is an unknown quantity at this point
Re: drl relay?
Thanks for this guys,
I had no DRL, and no left high beam. Found broken solder points on the 2 relays in the DRL control module (grey box under the dash, left of the steering column), re-soldered them, and now I am perfect.
Cheers
Old Jul 24, 2014
junbug's Avatar
junbug is an unknown quantity at this point
Re: drl relay?
Anyone know where the drl module might be or drl control unit located in a 2007 honda civic
Old Jul 24, 2014
junbug's Avatar
Re: drl relay?
jammer48
Oct 4, 2018 10:04 PM
h4ldol
Apr 24, 2017 08:16 PM
Deebo12
Air Conditioning
Sep 26, 2015 11:08 PM
pilebuck13
Sep 21, 2015 10:45 PM
Juanb24
Sep 15, 2015 12:39 AM
