Power Steering Pump Failing?
Whachya lookin at?
Well, seems my power steering pump is starting to go. Only when I first start the car up after not being driven for a while, it does not work for the first few turns and squeals. Then after that it works fine. I replaced the drive belt, does the power steering run on a separate belt? The fluid is okay. If the pump is going how long can I drive it without doing any further damage? Do I have to get it fixed or can I just drive the car without power steering? The pump is 250 dollars on majestic honda, are there any internal parts I can replace for cheaper that would fix the pump? Or is this a waste of time. Any help would be appreciated!
Re: Power Steering Pump Failing?
ps has its own belt yes, and it could be loose. eventually you need to replace the whole pump if its not working properly. and no you cannot just drive without ps, it will cause damage to the rack unless you convert to a breather system to allow fluid circulation.
Whachya lookin at?
Power steering belt has been replaced, still does it... hmm... I tried to add a bit of fluid too that did not help either... It's well between the lines ... I'm going to see if it gets worse and replace the pump if i need to
Whachya lookin at?
aye... and oy.... I'd definitely give that a try before replacing it. How long does majestic honda take to deliver... to canada? Also, are there any parts in there that could most likely be broken that I should order before taking it apart?
i dont think the inside parts are available. you pretty much clean it up or something and see what happens. the service manual has a 10 page section on rebuilding it.
moorebl
Aug 29, 2015 08:39 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
vvr210
May 31, 2015 08:02 PM
