Boot opening lever stuck
Old Oct 10, 2009
birdy's Avatar
birdy is an unknown quantity at this point
hello folks,
I have a 2001 Honda Civic. The other day I locked the car boot lever so that I could provide the valet key. However, when I unlocked the lever, I'm unable to open the boot from pulling the lever up. If I push the lever down, the fuel filler door does open. Any tips on how I can fix it? Appreciate it.
Old Oct 10, 2009
Re: Boot opening lever stuck
pry off the top plastic cover and see if you can wiggle the locking mechanism loose. also spray some silicone lube into it and try again. with the cover off, you can see much better what happens when you put the key in. it happens alot and you just need to move it back to the right spot.
Old Oct 10, 2009
birdy's Avatar
Thanks for the info. i was actually trying to pry off the plastic cover but I couldnt get it out completely. I just got the tabs off the driver side rail. are there any tabs inside too? Any tips on removing the plastic cover?
Since I couldnt open the plastic cover, I blindly sprayed WD-40 inside the lever mechanism.
Thanks once again.
jessica19699
Jul 29, 2015 05:51 AM
Nikipedia
Jul 28, 2015 10:50 PM
muttleytm
Jul 11, 2015 06:00 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
ballmich
Jul 9, 2015 11:59 AM
