Replaced Engine Hunting Idle
Old Sep 7, 2009
mainstreet98's Avatar
mainstreet98 is an unknown quantity at this point
I just replaced the engine in my 2002 Civic LX with an 85,000 mile engine. When I started it for the first time, it idled fine for about 3 minutes then started cycling between 1300 and 2300 RPM at about 1 second interval. The idle speed is constantly varying between these RPM. It also appears to be running hoter than my older Civics. Any suggestions?
Old Mar 26, 2010
locod1's Avatar
locod1 is an unknown quantity at this point
Re: Replaced Engine Hunting Idle
bump cuz im having the same problem. ive replaced everything on the TB including the TB itself. still a bouncing idle.
Old Mar 26, 2010
look at the top of the page - you will find the search button. click on it. you will see a window appear. type in idle - you should get some results.
search - means look for something in english.
you should get the following thread in the top. (note: click with your cursor in the underlined letters below.
https://www.civicforums.com/forums/3...eady-idle.html
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
thana
Jun 15, 2020 07:05 PM
thesushiboy
Apr 12, 2015 02:54 AM
usajags84
Apr 10, 2015 09:54 PM
