Default heat
Old Jul 9, 2009
zinkd's Avatar
zinkd is an unknown quantity at this point
Default heat
I bought a 2001 EX about a year ago. Periodically when I start the car, the heater is automatically engaged and won't turn off. Hitting the AC, changing the setting or turning the switch on and off has no effect. Sometimes it will disengage after a few minutes of fiddling and allow vent or AC to function, sometimes it will blow very hot air for 20 minutes before I can get it to change.
Since it occurs periodically, the Honda mechanic says he couldn't duplicate the problem and offered no possible solution.
Has anyone experienced this or have an idea what could be the cause?
Old Jul 10, 2009
hypnotic20's Avatar
hypnotic20 is an unknown quantity at this point
Re: Default heat
In all my life I've never heard of anything like that. Did you happen to take the dash apart to install a head unit? If so you might have crossed a wire or something. Did you buy the car used?
Old Jul 10, 2009
hypnotic20's Avatar
Re: Default heat
h4ldol
Apr 24, 2017 08:16 PM
Munzy
21
Oct 7, 2015 07:48 AM
jeffsasse
Sep 25, 2015 10:08 AM
hondalx2002
18
Sep 15, 2015 10:54 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
