Alternator light not turning off.
Hey all, well I've just had a very frustrating experience with a Honda Dealership. A couple days ago, my alternator light came on...when I got home I tested the battery, it read 12.5 V. Good. Started the car, and it read about 13.5 V, good. Put the system under load by turning everything on , and it sagged a bit, but hovered around 13.3-13.6 V. So I thought it wasn't my alternator or battery, and brought it into the local Honda Dealer.
Well, they told me it was my alternator. They said it was just "on the verge" of failing, and that I should replace it. So I say ok. Well, they call me when the jobs done, and tell me that the Alternator light is still on. Now I'm pretty livid, because I never thought it was the alternator, and I really felt like I just paid $500 for nothing.
Now I've got a wiring diagram, and I plan on doing continuity tests to see if all the lines are solid, and then start proofing out components in the charging system. I guess I'm hoping someone here might have some helpful advice on where to look, because I'm not the greatest when it comes to this stuff. I just wasnt gonna give them any more money to spend a few more hours of $110 labor and possibly find nothing.
Thanks.
Thanks.
Re: Alternator light not turning off.
I've tried. They gave me a 10% discount on the total cost. But that doesnt mean much when I still have the warning light up.
I don't know how much further I could get with this, they seemed to not want to budge anymore.
They at minimum should offer you some diagnostic time to see what the problem may be. ( if they charged you diag time it must not have taken long)
Maybe they could try an ELD unit ??
The ELD unit should be in my underhood fuse box correct?
I just looked for it and in the space where its supposed to be theres nothing.
2004 Civic SI, dont think I mentioned that. Is this normal???
Not sure where it was made, but I bought it in Canada. The manual for it looks like its not SI exclusive.
So I would presume its CA SI.
Is it Canadian Si = US EX ?? I can't say for sure.
Does the engine have 2 drive belts or 1 ??
Yessir, that was my point of reference.
Is it in a different place for Canadian models? The backside diagram of the fuse box makes no mention of it.
I will look into the drive belts after supper.
Im 99% sure its a US EX. It isnt the hatchback, and the engine is the same as the other models for that year.
K, thanks for everything so far Craig.
Not quite sure how to proceed next. Ive tested continuity between the plug on the alternator and the PCM, checks out. The other wires in the charging system are really not easy to get to. Not really confident taking things apart yet.
Think Im gonna have to try and negotiate with the dealership to treat this as a special case, and help me further, at a lesser charge.
Here are 2 pages from the manual for the indicator troubleshooting. Maybe they can be of help to you. There is only 1 schematic shown it includes the ELD. Pay attention to the notes to prevent ecm damage.
Ive gotten to step 8. I dont have the HDS, so I cant troubleshoot it further.
But looking at that, the tech at Honda told me to check continuity on those lines(steps 10-11), never mentioning that safety HDS part. So I may have damaged my PCM.
Is that pdf available online by the way? Also, if you could link the next page of the alternator/regulator troubleshooting.
Ok, got Honda to look at it again, and now they say its a defective PCM keeping the light on.
Being an almost $1000 repair, I think Ill live with the light and check my alternator every month.
Is there any reason to believe they are wrong?
trellex
May 24, 2015 04:39 PM
davidarenberg
May 16, 2015 08:45 AM
crowtoo
May 11, 2015 06:50 PM
cchance85
May 9, 2015 11:54 AM
SSMatey
Apr 13, 2015 06:09 PM
