Help!! Clicking/popping noise
Old May 21, 2009
david02civic's Avatar
I'm The Shit
david02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusted
Well I recently bought another 02 civic ex coupe 5speed. While driving it, usually while coming outta first gear and after shifting into second you can hear a clicking/popping noise. Seems like only when the car is moving and under a good amount of torque. The honda shop told me it was the compliance bushings. They wanted 450 bucks so I decided to do it myself.
I did everything right as I am somewhat mechanically inclined. The bushings didn't look too bad as compared to some of you on here. Anyway...the popping is still there. Only happpens going stright, no louder when turning or anything and the allignment shop said everything looks good to them, as in the CV axles and stuff. The struts dont appear to be leaking so I have no clue what else it could be. Any ideas?
Old May 22, 2009
dhaun113's Avatar
dhaun113 is an unknown quantity at this point
Re: Help!! Clicking/popping noise
I bought a used 04 dx. I had the same problem. For me it was actually coming from a rim that was not sitting flush. The sound was accompanied by shaking at 70 mph. I would take out the spare and throw it on a wheel and drive it around. Test all four wheels that way and if it stops have someone check out the rim. If that is the problem also replace the bolts for the lugnuts. 2 of mine snapped off after replacing the rim with one from the dealer.
Old May 23, 2009
I'm The Shit
Well it did it when i first bought it and since then i put 4 brand new tires on it and it does the same thing. I have taken the tires off a couple times then to do repairs. It has always done it
nirvanaguy
25
Oct 26, 2017 07:26 PM
fvckbg
Sep 8, 2015 09:55 PM
Josh 1973
Sep 7, 2015 10:10 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
tommycanada
Sep 5, 2015 04:59 PM
