Is repairing "compliance bushing" necessary?
Old Oct 11, 2008
lapchern's Avatar
lapchern is an unknown quantity at this point
took my car in for major maintenance at 80k and the dealer told me that my front compliance bushings are broken.
he quoted me about $500 (a bit less), but i did do some research here and saw that these aftermarket bushings last longer.
http://www.energysuspensionparts.com...prod=16%2E3116
can anyone else vouch for these? pros/cons?
most importantly... is there long term consequence if I dont repair this?
i haven't really noticed any issues with my driving...
Old Oct 12, 2008
DDragon7's Avatar
Re: Is repairing "compliance bushing" necessary?
When your compliance bushings are torn, they could cause excess tire wear. And yes, those energy suspension is a good long term replacement for them. They wont break as easily as the stock ones.
Old Oct 12, 2008
i love the ES bushings. stock ones tore on me around 80k miles or earlier, and cornering became much worse. also the car would not keep proper alignment since the rubber was torn and letting the suspension move around. ES are much better and handling will improve, they will also prolly last the life of the car. only small negative is sometimes they make some noise when its cold and you go over bumps and driveways. but for the most part regular driving, they are pretty quiet.
Old Oct 12, 2008
lordhelmet's Avatar
I need to get these. I am almost ready to roll over 150k. Is there anyway around using a press to get the old bushings out?
Old Oct 13, 2008
DDragon7's Avatar
Well, I think you can dremel or cut the old bushings out, but your going to need a press or vice to put the ES bushings in.
Old Oct 14, 2008
lordhelmet's Avatar
Vice: you are genius. I hadn't thought about that.
solarpunk70
Apr 12, 2016 11:43 AM
cferry7
Oct 18, 2015 06:32 PM
Sep 27, 2015 11:33 AM
curaze
Sep 22, 2015 08:27 AM
pilebuck13
Sep 21, 2015 10:45 PM
