Have I destroyed my engine?????
Old May 12, 2008
larrY C's Avatar
larrY C will become famous soon enough
I changed the oil and filter in my 2004 Civic Hybrid a little while ago as I always do. Except this time, I spaced out and cranked it up to back it off of the ramps WITHOUT ANY OIL IN IT!!! It ran about 15 seconds and then died. I realized what I'd done, put the oil in and cranked it. It ran 3-4 seconds and then died. I did this 5 or 6 more times because it was acting like it might start. By now I'm freaking out and instead of stopping and going in the house, I pumped the accelerator a few times and cranked it again. It coughed a few times and kind of backfired. Have I just bought myself an engine?
Old May 12, 2008
greeen01civic4d's Avatar
Re: Have I destroyed my engine?????
thats the way it sounds to me.....
Old May 12, 2008
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
well if the oil pump wasnt able to pick up any oil then it could just be dry so it cant create a vacuum. You need to prime the system by cranking the engine with the ECU fuse pulled out for about 30 seconds. Ive seen a few people have that happen. One was even at a honda dealer they forgot to put oil in. after an inspection they figured that it was fine but gave the guy an extended warrenty just incase
Old May 17, 2008
Jza's Avatar
Jza
Jza is a jewel in the roughJza is a jewel in the roughJza is a jewel in the roughJza is a jewel in the rough
curious to know, what happend with this?
Old May 17, 2008
dopes6070's Avatar
yah me too...
Old May 18, 2008
even if you ever get it working again, you took off over 100k miles of engine life.
MamaBear2015
26
Apr 16, 2015 11:08 PM
mazdamx3rs
Jan 20, 2002 07:38 PM
Aznnp77
Jan 7, 2002 03:12 PM
luukass
Dec 14, 2001 06:27 PM
2Hondaz
Nov 8, 2001 11:00 AM
