Clutch Pedal Problems
Old Mar 26, 2008
yock's Avatar
yock is an unknown quantity at this point
I did a quick search of the forums and couldnt find the answer, or maybe I missed it.
I have an 01 vic EX 5spd Manual. The clutch pedal has recently been giving me problems. When I push the pedal in to disengage the clutch the disengage point seems to change almost every time. When I start it in the morning when its about 35 degrees outside, the disengage point is closer to the floor. If I drive for a five miles or so the disengage point starts to move farther up until its near the point where the clutch is slipping and the pedal barely needs to be pushed to disengage the clutch.
Any suggestions? Bad Master/Slave Cylinder? Lines need to be bleed?
Thanks guys.
Old Apr 5, 2008
DDragon7's Avatar
Re: Clutch Pedal Problems
I got a similar problem, but never fixed. Bump for an answer.
Old Apr 5, 2008
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
The pedal just gets cranky when it's cold. Mine gets creaky and **** too.
Old Apr 16, 2008
yock's Avatar
Would that explain why when the clutch warms up that its at almost a constant point of having the clutch disengaged?
The clutch is extremely hard and its at this friction point of constantly slipping when it really warms up.
I'm going to double check it for leaks this weekend. The fluid level on the master cylinder is perfect. Could air bubbles in the line cause this?
Old Apr 16, 2008
TRIZ's Avatar
Thats not normal.
Old Apr 16, 2008
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
just a guess but,
it sounds like "hot spots" on the clutch causing it to slip...
its slipping that’s why it engages in different spots...
Old Apr 16, 2008
yock's Avatar
Originally Posted by 02BLKCIVIC
just a guess but,
So is a new clutch in order?
Sounds like i'll be taking it to a shop soon.
Old Apr 16, 2008
02BLKCIVIC's Avatar
how many miles?
stock clutch?
stock flywheel?
Old Apr 16, 2008
yock's Avatar
how many miles?
stock clutch?
stock flywheel?
63k
all stock i assume.(second owner)
Old Apr 16, 2008
02BLKCIVIC's Avatar
could beee
Old Apr 17, 2008
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
bring it to a shop and try to bleed the system. Sounds like when it warms up, air bubbles heating up?
Old Apr 17, 2008
DDragon7's Avatar
Done that before, still the same.
Old Apr 17, 2008
yock's Avatar
Have you tried anything else for this problem DDragon7?
Old Apr 17, 2008
DDragon7's Avatar
Nah, I gave up and lived with it unless someone else comes up with the answer. Changing the clutch cylinder or the clutch would be too expensive and not required yet.
Old Apr 18, 2008
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
I would be willing to bet if the shift fork and throwout bearing sliding surface on the transmission where greased the problem would go away. The only problem is that you have to drop the trans to do it. My Bro's 01 civic is doing the same thing so we are gonna check the clutch and grease all that stuff at the same time.
Old Apr 18, 2008
yock's Avatar
Interesting, keep us posted on how it turns out.
Old Jun 17, 2008
yock's Avatar
Just wanted to drop an update. I think I have solved my clutch problem. Seemed like the hydraulic pressure was building up too much. So i adjusted the clutch pedal a bit and backed it up slightly. The problem seems to have gone away.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ghondavic
Transmission
Apr 12, 2017 09:37 PM
bsmiley
Apr 27, 2015 01:27 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
02EXCoupeGuy
Dec 19, 2001 09:47 PM
