AC Reverse indiglo problems...
Old Apr 1, 2002
BLiTz's Avatar
BLiTz is an unknown quantity at this point
I installed my guages just fine and no problems. Now sometimes the gauges reset to the green setting even if I left it on the blue one. There are times when I turn them on the gauges don't turn on at all so I have to do the "turn off, turn on" game then they'll work. Even sometimes when I turn them on it'll just go through all the colors and brightness (which would be cool if my car was a strobe light). Is the wiring the problem or what? I spliced the positive to the left plug red wire w/black strip and the negative to the metal behind the gauge cluster. Please let me know if there's something wrong or if someone else has this problem.
Old Apr 8, 2002
RallyEX's Avatar
RallyEX is an unknown quantity at this point
Blitz: So you have the 6 or 7 color guages... I think this is your problem...
The controller that controls your Transformer is bad... sounds like the buttons are all flucked up. Perhaps it is also your transformer unit... The controller inside of there which talks to your buttons may not be controlling the Transformer or Transistor inside correctly. You will probably need a new transformer (not cheap, hard to find) or just purchase a new set of guages w/ transformer and re-use your old guage faces while using the new transformer.
nirvanaguy
25
Oct 26, 2017 07:26 PM
velozp
Dec 13, 2015 11:28 AM
ThatGuy913
Sep 28, 2015 05:35 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
BBrosario
Sep 17, 2015 07:51 PM
