EGR Problem major
Old Oct 17, 2007
Silverstreak04's Avatar
Silverstreak04 is an unknown quantity at this point
EGR Problem major
I am going on boost for the 3rd and finale time I found out why my motor keep blowing its my EGR... I have a new motor that uses no EGR. My head has no passages for the EGR to function properly. I was told I can loop 2 wires to make the Computer think the EGR works and it will get rid of check engine light.. Does anyone know what two wire I need to loop so I can Do this....
Old Oct 18, 2007
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
Re: EGR Problem major
read my post above this one "entire ex set up" based on that information, busted egr valve has no effect on the performance of the car. its just for fuel economy. to my understanding based on the information in that post. not 100% tho
Old Oct 18, 2007
Yeah it effects fuel economy very little though by like 3 miles less per gallom. But It has a 20% decrease effect on horse power. But Im not sure if my EGR is Bad or If the head does not have the ports for the EGR to work properly. I was told I can by pass it By jumping 2 wires but what two wires do i jump.
Old Oct 18, 2007
^^ i dont know if its just me but it just sounds like your pulling numbers out of your ***. boiler said he disabled the egr with kpro and if it has an effect on horsepower he obviously wouldnt have done that.
Old Oct 18, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
a lesson in EGR101
http://en.wikipedia.org/wiki/Exhaust_gas_recirculation
I know in some of my older cars, removing the EGR and blocking off the hole with a steel plate meant simply removing part of the emmissions meaning a tad more ponies. Same with the CATs in older cars, but todays cars are different....CATs are generally found right in the cast header or such and EGRs are dependant on the ECU vise versa, so you cant just remove it without consiquences unless like mentioned where electronically closing it off via K-Pro
Old Oct 18, 2007
So i either need to close it off with Kpro... But I put in my Emanage Blue and drove all day with in the car and my check engine light for the egr never back on.. usually it comes back on after i have i have shut off the car and started 4 times through out the day.... How do you fix the jerking i get with emange until the car passes like 4000 RPM Its driving me nuts I have stock injector and no boost yet all the maps are turned off and I am only using the timing map anyone have a suggestion
7thgensurvivor
38
Aug 29, 2015 11:50 AM
siCaddie
Jun 2, 2015 07:35 PM
Blaster30
Apr 22, 2015 12:21 PM
blacklud
Apr 13, 2015 06:15 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
