Help, Truck Release Does not work.
Old Oct 15, 2007
okita368's Avatar
okita368 is an unknown quantity at this point
Hi, can anyone help me with my trunk release. I locked it and now it does not unlock. So now when i pull the lever for the trunk nothing happens, it will not move. The only way for me to open the trunk is to stick the key in from the back of the car. Does anyone know how to fix this problem? and will it be expensive?
I have a 2001 civic lx coupe, canadian model
Thanks in advance,
Okita
Old Oct 15, 2007
cody123's Avatar
cody123 can only hope to improve
Re: Help, Truck Release Does not work.
should be a place where you can put your key in on the trunk/gas release insert the key and then turn to the left i belive is the ulock then it should relase normally after you unlock it.
In lamens terms do exactly what you did to lock it in reverse
hope im right and this helps
Old Oct 15, 2007
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
The guy said he can't unlock it.....
You need to provide more information like what happens when you try to unlock it. Does the key turn and it doesn't unlock, or does the key not turn because of resistance? Try taking it apart, you can do it in just a few minutes by removing the plastic parts.
Old Oct 15, 2007
okita368's Avatar
Hi Dex,
thanks for the quick response. As for what happen: I stuck my key in it and turned it then turned it back, then 2 hours later I tried to open trunk and it would not open. So i stuck the key in it to see if i locked it. I can put the key in fine withi no resistance and turn it both ways but it does not let me unlock the trunk. I am not really mechanically inclined but how do i take it apart and what do i do after i take off the plastic thing.
Old Oct 15, 2007
greeen01civic4d's Avatar
can u even get into the trunk? if not, fold down ur rear seats, and climb through, there is an interior release for the trunk, u might just have a jammed cable, but i think there is a fix for this, i think ur cable broke, someone posted the fix on here at one point, ill see if i can find it
Old Oct 15, 2007
okita368's Avatar
I can get into the trunk, I just have to go outside and stick the key in to open it.
QUOTE=greeen01civic4d;4251584]can u even get into the trunk? if not, fold down ur rear seats, and climb through, there is an interior release for the trunk, u might just have a jammed cable, but i think there is a fix for this, i think ur cable broke, someone posted the fix on here at one point, ill see if i can find it[/QUOTE]
Old Oct 15, 2007
MURDOCK's Avatar
My cats breath smells like cat food.
MURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond repute
Here this link might help you out
http://www.fueldoorfix.com/
Old Oct 15, 2007
damnit murdock, u beat me again, i was almost there
Old Oct 15, 2007
MURDOCK's Avatar
haha sorry Adam but I remember I saw this add a few days ago.
There still might be another way to fix it though
Old Oct 15, 2007
AmbulanceMonkee's Avatar
i read somewhere on this site about that little lock near the lever getting full of sand, dirt, whatever, and this happening. you're not the first to have this problem. as soon as i read that, i decided never to mess with the thing. as far as what to do, you're going to have to take it apart, i think. that was a good link, as it should show the inner workings of the lock/lever assembly on the floor. Or, i guess you could just stick to unlocking it at the trunk, tho i could see that becoming a huge pain in the ***.
Old Oct 15, 2007
some helpful, and some not so helpful, but entertaining, links.
https://www.civicforums.com/forums/7...need-help.html
https://www.civicforums.com/forums/3...locked-up.html
https://www.civicforums.com/forums/3...unk-latch.html
Old Oct 15, 2007
okita368's Avatar
hi all, thanks for the website, so that is most likely my problem or could it be something else? Do you guys know of a way to make sure of that before i buy it?
Old Oct 15, 2007
i think it's the lock itself that's fubar'd. i think you should use the installation instructions on the site, as a guide for taking it apart, and looking at it, to see if you can manually unlock it by turning the cylinder, or something, before you buy anything.
Old Oct 15, 2007
okita368's Avatar
ok thanks, hopefully all goes well. I've never done anything before lol
Old Oct 15, 2007
that sounds like a boring life.....
Old Oct 15, 2007
okita368's Avatar
did you learn how to fix/mod cars on your own or did you take a course or something to help?
Old Oct 15, 2007
all self taught baby, im kinda mechanically inclined, but ive worked with cars for a living for the last 6 years, so that helps, plus i work at a ford dealership, which helps too, but u dont learn from not doing, u learn from diving in, making mistakes, and getting ur hands dirty, get urself a haynes manual, some tools, hand cleaner, and dive in, ull learn a lot, and maybe save some money too
Old Oct 16, 2007
DeX's Avatar
DeX
Canadian, Eh!
I have one last question. When you turn the key to unlock the trunk and pull the lever, does the lever move or does it feel the same as when it's locked?
Old Oct 16, 2007
did you look at the trunk latch? sometimes the ball comes off its groove.
Old Oct 16, 2007
MURDOCK's Avatar
I would not even bother trying to help this ungrateful little sod anymore he didn't even bother to rep me for providing him with the web site for the god damned cable fix.
Old Oct 16, 2007
okita368's Avatar
After i turn the key or if I don't turn it the lever only still releases the gas door the trunk wont open, i can not pull it up.
Old Oct 16, 2007
okita368's Avatar
what does rep do and how do i give it to you. Is it the donate thing?
Old Oct 16, 2007
okita368's Avatar
never mind i found it.
Old Oct 16, 2007
MURDOCK's Avatar
Ok here is what you do take your ignition key and climb into the back seats on the back dash there is a lock to unlock the back seats and fold them down.
Crawl into the trunk there is an emergency lever located on the latch of the trunk pull it and your trunk will open.
or you can just open it from outside lol.
Old Oct 16, 2007
when the release is locked, it shouldnt pull up at all, at least mine doesnt, i bet the cable broke free from teh latch, there are two cables attached to teh lever, one for the trunk and one for the gas door, i bet the trunk release one is either broken, or pulled free, id take it apart and check, i bet the holder on the latch is broken
Old Oct 17, 2007
if he can't pull it up, like he said, it's still locked. it's not a cable issue. the cable is still firmly attached to the lever, and to the latch inside the trunk. take the damned thing apart, and fvck with the lock near the lever inside the car.
Old Oct 17, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
Call me a Whambulance cuz im laughing so faking hard im actually crying !!
MUAHAHAHAHAHAHAHAHH!!
even funnier...
i can see this guy crawling into his trunk all to come back here and post "I cant open the E-HAtch" on my damn car?
Old Oct 17, 2007
MURDOCK's Avatar
even funnier...
Because you know funny when you see it. +1 for u
Old Oct 17, 2007
DeX's Avatar
DeX
Canadian, Eh!
Exactly. That's what I thought it was.
Old Oct 17, 2007
CraigW's Avatar
I have a TSB that pertains to similar problem, it shows removal procedure and other info on the trunk/fuel release assembly. It sounds like the lock is somehow bound up.
It is not in PDF format, but would be willing to scan if someone needs it let me know.
