Special slave cylinder knowledge required
Old Apr 24, 2007
chopper202's Avatar
chopper202 is an unknown quantity at this point
Bobsagator told me to post this question here for some help..Ive had a squeaky clutch for a while now, I searched around on how to fix it and and I found out how and it was good for a while until I got a bit of heavy rain and now it has come back worse than before... I cannot get rid of it ... I have taken it apart twice and greased it up real good both times with lithium grease... There is one problem that I can see that might be causing it... and its within the slave cylinder, the ball joint specificley, it is quite worn I have a picture from a thread I posted in before...sorry for the large image size
Im not experienced with this type of clutch.. because my other car has a completley different setup.. im not sure if has any thing to do with the ball joint or something completley different.. Thanks for any help on the subject... But I have read evey clutch thread out there on this subject so I carnt search anymore...
Old Apr 25, 2007
solar's Avatar
solar is an unknown quantity at this point
Re: Special slave cylinder knowledge required
If I remember correctly Honda issued a Service Bulliten for squeaky slave cylinders. You might want to call the dealer and see if it's still valid, I know that quite a few people have had to change out the slave because it squeaked.
Old Apr 26, 2007
chopper202's Avatar
Thanks for that I gave honda a call in my lunch break and that isnt goin on anymore in Australia I dont know if its still on in America but they said that I could bring it in and they would replace it at a price but they wouldnt know how much until I bought it in... im just going to have a go at replacing the ball joint and see if that helps me at all...
Old Apr 26, 2007
AmbulanceMonkee's Avatar
i was aware of the TSB for some issue with the clutch master cylinder that may cause it to squeak. i made multiple trips to honda, and they even replaced the master and the squeak continued. what finally ended up fixing it was when they "buffed some oxidation off the piston of the slave cylinder." <- their words. mine has started squeaking again. i will mention the ball joint to them when i take it in, and try to remember to let you know what they say here in the US.
Old May 20, 2007
chopper202's Avatar
Ive been searching around the junk yards and I got a slave cylinder piston that looked new no wear or oxidation... I instaled it and what do you know it still squeaks... AmbulanceMonkee I know ive said this before but I know the sound is coming from the slave cylinder not the master cylinder but since ive replaced the piston and can see nothing wrong with the actuall slave could it be the fork that the piston pushes against or where it connects to... I remember back to when I put my clutch in and I remember it being pretty complex in there but is there something in there that could be stuffing up???...
OptimisticWay
46
Oct 15, 2015 02:16 PM
muniorbust
33
Aug 31, 2015 08:59 PM
DerbyDad03
Jul 27, 2015 11:34 AM
califcamper
Jul 21, 2015 10:34 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
