Clutch might be bad/ its easy to grind in 2nd & 3rd gear Y
Old Jan 8, 2007
01civic20's Avatar
01civic20 is an unknown quantity at this point
Recently when i drive, its easy to miss 2nd and 3rd gear when shifting which causes it to grind. also there seems to be more play in the movement when in neutral just pushing the shifter towards each gear without going to the gear all the way. Y is this. Respond back soon thanks.
Old Jan 17, 2007
valenzuela's Avatar
valenzuela should not be trustedvalenzuela should not be trustedvalenzuela should not be trusted
same goes this way! id like to know to i cant figure it out. i thought mayeb a bad throwout bearing?
Old Dec 16, 2013
bacascooby's Avatar
SOUTHERN SLEEPERS CAR CLUB WACO, TX
bacascooby is an unknown quantity at this point
Re: Clutch might be bad/ its easy to grind in 2nd & 3rd gear Y
Check shift key or sencros
Old Dec 16, 2013
mikey1's Avatar
do you realize this thread is almost 7 years old??
lapchern
Jun 4, 2015 04:35 PM
Marcus2thextrem
May 10, 2015 03:08 PM
conspiracy90
Jan 19, 2002 08:37 PM
conspiracy90
Jan 19, 2002 03:21 AM
Russps
Nov 8, 2001 02:00 AM
