replacing motor mount
Old Oct 30, 2006
hcivic0120's Avatar
hcivic0120 is an unknown quantity at this point
Does anyone know where to find cheap motor mounts. I need to replace the motor mount that is located by the timing belt. And the metal arm thing is fine, its just the rubber that is cracked. Do they sell just those, i think there motor mount inserts and if so Where? thank you.
Old Oct 30, 2006
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
for the side mounts your pretty much stuck with OEM honda mounts. They do make inserts for the front/rear but they are poly so you feel much more engine vibration. the front and rears usually go before the sides so check those for cracking.
Old Oct 30, 2006
hcivic0120's Avatar
Where is the cheapest place to buy them, like online sites to? and all of the 4 motor mounts can you pretty much do yourself easily
Old Oct 30, 2006
dopes6070's Avatar
ya they are pretty easy just do 1 at a time. TRY www.slhondaparts.com AND www.hondaautomotiveparts.com
Old Oct 30, 2006
hcivic0120's Avatar
So what is that piece called, like just the rubber that is cracked, not including the whole metal bracket? and you said you have to buy the whole piece?
Old Oct 30, 2006
dopes6070's Avatar
The rubber is molded into a metal bracket so yes the whole thing has to be replaced, The whole thing is a motor mount. This is for the Auto civic. if yours is manual there is another page for that
http://www.hondaautomotiveparts.com/...8AT%29+%282%29
Old Oct 31, 2006
SOHC_VTEC_pwr's Avatar
SOHC_VTEC_pwr is an unknown quantity at this point
call car quest or any other parts store. I put in a motor mount in a 99 civic it was easy as hell. Just a few bolts and it came out. But idk if its the same as the 7th gens. Good luck i know car quest have em but idk for our cars.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Jigee
May 9, 2015 11:18 AM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
GH04si
Apr 15, 2015 08:13 PM
