Engine Delay?
Old Sep 26, 2006
memorex's Avatar
memorex is an unknown quantity at this point
Engine Delay?
I noticed that when I am driving and start a heavy increase in throttle that it has recently been delaying the power.
In other words, it will be a sudden delay and then wil quickly accelerate like normal.
I did this today, and it delayed a little longer then normal. I stop right away and notice my check engine light on.
All I have in an intake, and I've had it for about 2 years now. The motor does have oil, but it seems to have a faint smell of gas in the oil.
Any idea on what the possible problem could be guys?
Old Sep 26, 2006
well if the light came on get the code read at advance or autozone. it will tell you the problem. i would look at that first, then based on that i can tell you other things to check.
Old Sep 26, 2006
HondaLuver's Avatar
Its a celebration bitches!
your cars slow, deal with it.. hah
Old Oct 2, 2006
sb143hd's Avatar
sb143hd is an unknown quantity at this point
I have a similar problem, and I had my code read and it said it was a p1300 (multiple cylinder misfire) I believe! Good luck figuring it out!
Old Oct 2, 2006
did you try changing the plugs?
Old Oct 2, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
what gearbox said
Old Oct 5, 2006
memorex's Avatar
Turned out to be Vtec Presure Sensor..
I didn't have much oil in the car..
Old Oct 5, 2006
puidokas's Avatar
puidokas is an unknown quantity at this point
You must have been pretty low on oil
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bluecoupe
Jan 23, 2002 05:50 PM
CapYoda
Jan 7, 2002 03:20 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
