My tire has horrible inner wear
Old Sep 24, 2006
blackBDMcivicLX's Avatar
For every sprinkle I find, I shall kill you.
blackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant future
A few years back I had an accident where someone pulled out in front of me and my front passeneger side when head on with his rear passenger side. I've noticed over time that my fron passenger tire is significantly worn down on the inside of that wheel. None of my other tires have the problem. I need to get new tires for my expection next month but I don't want to buy new tires just to have this keep happening. Any ideas what it could be? Thanks.
In a nut shell...
  1. Accident few years back that hit front passenger side.
  2. Front passenger tire has ALOT more wear on the inside than the outside.
  3. No other tires affected.
Old Sep 24, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
as with all accidents... get yer alignment and camber checked after... then stuff like this wont happen...
Old Sep 24, 2006
ya didnt you get an alignment after?
Old Sep 24, 2006
They said they did it. You think thats the problem?
Old Sep 24, 2006
RHCP0801's Avatar
im about 99.9% sure its the camber and alignment
Old Sep 24, 2006
burke420's Avatar
The World Is Yours!
plus, wouldnt the axle accelerating, since a aka one-wheel-wonder burn-outs affect your tire wear, but most likely the camber and alignment.
Old Sep 24, 2006
Oh by the way, I'm on stock steelies with no suspension mods. Would I just need to take it to get aligned or would I have to have something else done to it?
Old Sep 24, 2006
if you have stock springs and shocks, yes just take it to alignment shop. it can be adjusted within factory spec. camber kit is only for lowered rides.
Old Sep 24, 2006
Ya I know about camber kits and all that but i kept seeing camber so I wanted to make sure I wasn't being stupid. Ok thanks guys. I'm going to try to make a trip to get this done before I buy the new tires. Will they be able to tell me if it is way off while they are doing it?
Old Sep 24, 2006
ya they should give you a spec sheet with bad values in red at first and then a second sheet with everything in the green.
Old Sep 24, 2006
streetglower's Avatar
I would buy the new tires and get an alignment at the same time. its not recommended to align the car with the old and worn out tires.
Old Sep 24, 2006
Ahhh thanks for the heads up. Definately what I'll do then.
Old Sep 24, 2006
blackbox_06's Avatar
blackbox_06 is an unknown quantity at this point
yea you should get the new tires and do whatever you going to do to it as far as ride height is concerned bc you may need to get another alignment if you alter that too much
Old Sep 24, 2006
I don't have the money to modify the car now. If I do lower it or anything like that, I'll need a new job that pays more or a big raise. And right now the hours I work are great 6-2:30.
Old Sep 24, 2006
ya alignment is the last thing you do, after installing new parts like spring, tires etc
Old Sep 24, 2006
Ok thanks everyone. Hopefully it is just the alignment and not something worse.
Old Oct 3, 2006
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
ya trust me its an alignment. i do alagnments myself, it should take about 30 min if they know what theyre doing. jif its just on the front passenger, just have them do a fea(front end alignment) its cheaper and faster and will have the same results. also, rotating your tires every 5000 miles will help some but not alot.
Old Oct 5, 2006
ultimatetuner10's Avatar
Technical Assistant
ultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond repute
My car has a bent control arm, and that was doin it. Soon as they were replaced, it was all done. They were like 110 a piece from autopartswarehouse
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
alaga
25
Aug 13, 2015 04:42 PM
Curtchuk
Aug 5, 2015 02:14 PM
