Sound when Lights Left On Doesn't Work (Revived Thread
Old Jul 13, 2006
Aznnp77's Avatar
All Show No Go Sedan
Aznnp77 will become famous soon enoughAznnp77 will become famous soon enough
I tried to revive my old post, but the system wouldn't let me.
http://www.7thgencivic.com/forums/sh...d.php?t=208314
This is the original post, great help guys, thanks
Hey guys, it's been going on for about a year or two now, but I never got around to fixing it. The beeping noise that is suppose to come on when u turn off your car and have your lights on doesn't work anymore. I dealt with it for a while, but I've done it twice in the past 2 weeks, and had to have a friend come by to jumpstart me. Is there like a fuse somewhere that I blew out? I checked the ECU/Fuse box and I don't think there is a fuse for something like that. Hopefully this doesn't require me to dig too deep into the car, cuz I'm not good with technical stuff.
Wow, sorry to revive this topic from the dead, but I have finally gotten around to wanting to fix this problem. I went to my front door to try and find those stops, but I wasn't sure which one it was. If you guys could be so kind as to tell me which one it is, and possibly how to install it, I would appreciate it. Theres those screws under the top one, I don't wanna touch em unless I have to. I realize I never turn my lights on until it gets really dark cuz I'm afraid of forgetting and leaving them on.
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=Civic&catcgry 2=2001&catcgry3=4DR+EX&catcgry4=KA4AT&catcgry5=FRO NT+DOOR+PANELS
I think it's #16 or 20, I'm not sure though.
Old Jul 13, 2006
CraigW's Avatar
Does the dome light come on when the drivers door is opened ??
If not check the door switch, peel back the cover to reveal phillips head screw. Remove connector.
Old Jul 14, 2006
Aznnp77's Avatar
the dome light comes on when i use my keyless entry. I never actually opened the door in the dark without my keyless entry so i dunno.
Old Jul 14, 2006
CraigW's Avatar
I have heard the door switches can give troubles. You could always swap it with the passenger side switch.
Old Jul 17, 2006
Aznnp77's Avatar
I had the door switch on the driver's side replaced. Ur right, just a 2 min installation if you know where it goes. Well, it still didn't fix the problem though. My car still doesn't make that "u left ur headlights on idiot" beep. Any more ideas guys?
Old Jul 18, 2006
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
the switch uses the body as the ground, so when the switch is pused in it grounds the wire to the body...make sure that you have good connections between the switch and the body is all i could really recomend, other than that check fuses, etc. also you might be able to trace the wire back to the ecu to make sure it's got a good connection there as well
Old Jul 18, 2006
CraigW's Avatar
Does your "key in ignition w/door open" sound still occur ?? (they are the same piezo unit)
Old Jul 20, 2006
Aznnp77's Avatar
Nevermind. The beep only comes on when the lights are on and the door is open. I don't tihnk I remember it being like that, but owell. Problem solved for 8 dollars. Thanks guys.
Old Jul 21, 2006
booba5185's Avatar
it should beep when the key is in the ingnition but not turned (with the doro open), the lights are on (and the car is off with the door open), and when the car is started with no driver seatbelt on. Thats the only times that i can think of that it beeps anyone feel free to correct me if i'm wrong.
slynger
18
May 8, 2015 06:06 PM
Dorval Andre
May 1, 2015 09:37 AM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
darwin-t
Apr 18, 2015 09:29 PM
Russps
Nov 8, 2001 02:00 AM
