Clicking Noise Turning Right?
Old Jul 10, 2006
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
I've been getting a clicking noise making right hand turns, I searched but didn't fin much info.
Car is a manual and it does do it in mostly second, what do you guys think?
Old Jul 10, 2006
bad cv joint?
Old Jul 12, 2006
dariusld's Avatar
dariusld is an unknown quantity at this point
You could try this to see if its the CV joint. Turn in a circle at slow speeds and if you here click click click click click click click click click it is your cv joint. Check the outer cv joint boots for lots of grease, it usually gets on alot of other things also. I check my boots every now and then for cracks, rips, or grease.
Old Jul 12, 2006
Inboard or outboard?
Old Jul 12, 2006
hauliau's Avatar
hauliau is an unknown quantity at this point
I'll bet your strut is leaking.
Old Jul 12, 2006
R3DL1N3's Avatar
i'm having the exact same problem.
Old Jul 12, 2006
dariusld's Avatar
The one closes to the wheel is the one that gets all the work, check that one. I'm guessing if there isn't a bunch of grease on your boot, then it's probably not the cv joint
Old Jul 14, 2006
modoman's Avatar
i have the same thing, except the grease is on the inside boot. oh well for now.
Old Jul 16, 2006
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
just my 2cents. get down to the basics. maybe your lugnuts are loose, go tighten them up see if that solves it
Old Jul 24, 2006
cannonfolder's Avatar
cannonfolder is an unknown quantity at this point
ok man listen do this,by the way i hope ur still under warenty.I had the same problem looked everywhere but i couldn't find the solution.You guys will never believe this but it's true,I also had a hard time believing it myself but it is a defective peice in the transmition that recieves tourque when turning right.I sent it to the dealer and they fixed it.If it is not coverd by warrenty,I think it was around 1000$ bucks canadian.I don't care if you guys think it's bullshit,all I know is when I got my car back it was running perfect with no noise.
Old Jul 24, 2006
teg91ls's Avatar
teg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trusted
it is obviously the cv boot or joint, that basic car knowledge
Old Jul 24, 2006
I agree, I thought it was that at first but it ended up being the tranny
Old Aug 3, 2006
jimmys2000's Avatar
jimmys2000 is an unknown quantity at this point
Its not the cv joints.. Ive done loads on gearbox mods.. In the gearbox there is the reverse gear selector arm. Inside the arm is a ball bearing and spring arm. what happens is the spring goes weak and the selector arm moves around, funnily enough it rattles on second gear.
Hope this helps..
Old May 8, 2012
anonymousalecks's Avatar
anonymousalecks is an unknown quantity at this point
Re: Clicking Noise Turning Right?
I bought my buddies 02 civic off him cause my car got stolen n it seemed reliable. Right off the hop i had to put a full new exhaust in, no big deal.. but it seems like this car is notorious for head gaskets leaks, and due to slight loss in coolant.. and the occasional overheating when i come to an idle.. seems like i may have that problem.. but worse off.. the clutch just went last friday, and i had it towed to the shop.. ordered a new clutch kit, had it replaced. now the shop tells me my whole tranny is noisy. some kind of messed bearings or some bullshit inside. and the whole thing needs to be rebuilt... you guys are mentioning the clicking noise on right turns.. my car has done that exact thing from the day i bought it and i tried to figure out what it is the whole time. with no luck.. definetly not cv joints doesnt seem to be suspension at all.. ONLY does it when turning right... typically in second gear.. but who turns in any other gear? does anybody know much about this? what im worried about is letting my shop "rebuild the tranny" for whatever reason they see fit.. will this fix the clicking noise when i turn right? or will it remain? and worse off will i end up buying another new tranny/clutch in 30k km any help would be much appreciated
Old May 9, 2012
06_typeS's Avatar
06_typeS is an unknown quantity at this point
Im in the same boat here. Noticed it this week turning right in second gear. Could it be the wheel bearing?
Old May 9, 2012
yogeshsr's Avatar
yogeshsr is an unknown quantity at this point
I hv same problem when turning left OR right, the noise(friction of metal with metal) comes from rear right passenger side. usually happens when speed is low.
Old Jul 23, 2012
so i had my tranny rebuilt at the shop, new clutch. head gasket still seems to be letting exhaust gas into my rad.. overpressurising and pushing coolant out.. eventually causing it to overheat.. im talking days tho.. but worse off.. it still clicks in 2nd gear when turning right.. the more you do it.. the noisier it seems to get.. im imagining worse? ... what can be done about this? the guys at my shop dont seem to understand my "explanation of what i think it is"
civicns
May 8, 2015 09:49 PM
jetcare101
May 8, 2015 01:33 PM
edgenet
May 2, 2015 08:00 PM
Dorval Andre
May 1, 2015 09:37 AM
Sparty
May 27, 2002 12:30 AM
