Check engine light on
Old Feb 5, 2006
Slow Gold's Avatar
I hope I offend you... Get mad
Slow Gold will become famous soon enoughSlow Gold will become famous soon enough
Well i went to Advance auto and they ran the obd2 code scanner and found P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2) so wtf does that mean. How do i know if i have a bad oxygen sensor. All i have done to my car is a megan header and a catback still have the stock cat. Ive had all my mods for the past year and nothing till yesterday now the car idles like **** and when i tried to reset the ecu it did but then the light came right back on also the car lost all of the little ***** it had. any ideas?
Old Feb 5, 2006
streetglower's Avatar
replace the 02 sensor. Its going to be the 02 sensor at the cat converter. the idleing like **** is from that faulty o2 sensor. replace it and you should be good to go. usually I would tell you to diagnosis the check engine light first just to make sure you have no wiring problems or anyting, But I am pretty sure its the o2 sensor.
Old Feb 5, 2006
Slow Gold's Avatar
Thanx, im going to try the mechanical 02 simulaters with the spark plug non foulers tommorow. If they dont cure the problem i'll buy the 02 sensor.
Old Feb 6, 2006
why not just buy a new o2 sensor? it is about $60 from the dealer, $40 from majestic honda.
Old Feb 6, 2006
Slow Gold's Avatar
I ordered the one in the downpipe from this site http://www.partsandaccessories.com/o...e=1-dot-7l_gas pretty cheap for bosch.
Old Feb 7, 2006
gmcuajo's Avatar
gmcuajo can only hope to improve
I think you refer "the 02 sensor at the cat converter" to the secondary sensor after the cat converter. If the car is "idleing like a ****" the secondary sensor haven't any influence on it. This secondary sensor is just for cat efficiency, not for engine management...
Check the primary O2 sensor.
Old Feb 7, 2006
Slow Gold's Avatar
I'll leave it to honda... the engine blew a hole in cylinder # 4 yesterday so i'll let them and my warranty fix all the bs..
Old Feb 7, 2006
this is correct
Old Feb 7, 2006
although that is correct about the sensor, but the code given was for bank 1 sensor 2. that isnt the primary sensor. that is the sensor monitoring the cat. Now that sensor can play a role in the air/fuel mixture. yes it does monitor the cat converter and signals the ECU that it is working or not working, but when the sensor itself goes bad, it can effect engine perfomance. and if the check engine light is on and the car runs rough, 9 times out of 10 it is because of that problem.
Old Feb 7, 2006
oh okay its actually saying the sensor is bad not just emissions cel. makes sense
Old Feb 7, 2006
correct. the code is actually for the secondary o2 sensor, not the catalyst.
Old Feb 9, 2006
sil04ver's Avatar
sil04ver is an unknown quantity at this point
I have the same code, from when I put an EX exhaust system on my DX. Bought a wire-in MIL eliminator, didnt work. Bought a Caspers plug-n-play eliminator, didnt work. Gonna try and replace the o2 sensor this time, I dont wanna have to sell my header and exhaust
Old Feb 12, 2006
Slow Gold's Avatar
this can be closed
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
