Whining Noise From Engine
Old Jan 19, 2010
  #31
theman's Avatar
theman is an unknown quantity at this point
Re: Whining Noise From Engine
Hello, did you mean serpentine belts?, i'll check if they are due, but i have completed a timing belt change as well last year. only when winter hits the whining started. i'll check it out , thanks for the advice.
Old Jan 19, 2010
  #32
well we have three belts: timing, ac/alt, and ps. the ac/alt and ps belts are just called accessory belts.
Old Jan 19, 2010
  #33
Xplod590's Avatar
Xplod590 is an unknown quantity at this point
I have got the same problem. I have already replaced both acc belts on mine about a month ago and i still here it. I do have subs installed. If it isnt the belts what would you guys suggest? i am goin to take it to the garage this weekend if i cant find figure it out. Anything will help out guys. Thanks
Old Jan 27, 2010
  #34
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
if it's an auto transmission, it could be your tranny. In my case, it was the transmission going bad. sorry to say it was $2k to fix. Hopefully you can narrow it down to something else...
Old Jan 29, 2010
  #35
jgg204's Avatar
jgg204 is an unknown quantity at this point
i had the whining problem on my Civic. it would whine in the morning when it was cold out. then, the transmission started slipping. then it was about to die when i was miraculously able to roll into a dealership and yes, the transmission was mechanically failing on a 7th generation civic (what a surprise!!!!??!!?....sarcastic). anyways, honda agreed to pay for $1,000 towards my repair since i had a 2003 with only 70K miles.
anyways, i have a new factory rebuilt transmission and no more whining.
Old May 5, 2010
  #36
theman's Avatar
It's too late for me guys , My car just broke down in the middle of an intersection and the car won't move in any gears. I did the check on belts, flush the ps, flush on the auto trans. to diagnose the whining sound. Today i found out what it was, it's the transmission dead at 176,000 KMS. Having a used one for 1250 with labor installed. damn honda. I have a 96 with 280,000 kms and still run good. disappointed. this will be my last honda.
Old May 5, 2010
  #37
BlueEM2's Avatar
Whachya lookin at?
Damn 1 breakdown and you no longer want a honda? At 176, 000 tell me how anyone elses cars are running... These things are pretty damn reliable for the most part. When is the last time you changed the tranny fluid before this last time?
Old May 5, 2010
  #38
theman's Avatar
Understood man, but i had high hopes for this honda to go the distance, did not expect honda obviously has an issue here. How many times do we expect a tranny problem 1,2, times? this are not cheap, anyways, thanks
Old May 6, 2010
  #39
theman's Avatar
Ok guys, the civic is back in business after $1250 on a used 04 transmission. So far so good, a bit hard on shifting from Park on the gear, but the drive is smooth. I'll need to test drive it for a week, then have a tranny flush.
Old May 6, 2010
  #40
BlueEM2's Avatar
Whachya lookin at?
Glad to hear your back in action. 1250 is a Great price for a transmission installed, used or not.
Old May 7, 2010
  #41
theman's Avatar
thanks man.. gonna be gentle on the accelerator until it i "break-in" properly. thanks all for the support, this is an awesome site for honda's for sure. hands down to you all guys. / gals.
cheers
the man
Old Sep 8, 2010
  #42
rcelefano's Avatar
rcelefano is an unknown quantity at this point
Great. That scares me, what you went through 'theMan'.
The whining noise started for me as well. Its the sound of reversing the car, but I'm actually going forward. It's most prominent when I gear down from 3rd to 2nd, averaging around 3k rpm's when I let go of the clutch onto 2nd.
Jeez, does this mean I have to save up money, because I'm most likely going to need a new transmission? If so, I might as well start looking for another car... I've grown tired of all the things I've had to fix on this car.
ALTHOUGH, the car hasn't broken down on me yet. But then again, it's only 145,000km's. I expected it to hit at least 230,000 without a break down. My dads camry is going that distance without any issues.
Old Sep 8, 2010
  #43
my car has all sorts of whining and growling and mechanical noises, but engine still runs okay. so idk, if it drives normally youre prolly fine. does the car shift gears smoothly or does it rev up between shifts?
Old Sep 9, 2010
  #44
rcelefano's Avatar
I'm driving a manual car, so if the engine revs up while changing gears/doesn't shift smoothly, it's most likely my fault lol.
The noise is getting louder, the clutch hesitates to catch while I'm launching slowly. I'm going to my mechanics tonight so he can diagnose everything and price out how much everything is going to cost me...
I'm looking at how much I can sell my car for and it doesn't even seem worth it lol. So I'm probably just going to get the issue fixed and keep the car.
I guess I might as well get my tokico's replaced as well. They seem to be shot. Good ol lifetime warranty
Old Sep 9, 2010
  #45
how long on the tokicos? im almost 4 yrs in and they still sit and work perfectly on lowering springs.
Old Sep 9, 2010
  #46
rcelefano's Avatar
About 5 years on the tokico's. Around 60,000km's.
Confirmed that my transmission is going. Only a matter of time now.
My mechanic said it could cost around $1100 to get a rebuilt transmission installed. The thing I'm debating about now is, should I sell it after I get it replaced. One of the mechanics there has a 2005 civic dx, manual, 90,000km's and he has the exact same problem as me(us)...
Old Sep 15, 2010
  #47
Stipster's Avatar
Stipster is an unknown quantity at this point
Im getting a pretty quiet qhining noise aswell from start up to normal running temp, my civic is an 04 5spd with 250 000 kms on the clock, does this sound like tranny related?? I know my throwout bearing squeaks when I press on and release the clutch and has been doing it for a few yrs now
Old Sep 17, 2010
  #48
Olliemo's Avatar
Olliemo is an unknown quantity at this point
I have an '02 and it has started making that same sound too. But mine isn't right at start up. It's after I've been driving and then stop and idle, then when i start driving again it starts up. One thing i've noticed is when i turn the wheel while i'm idling it gets louder, also when i accelerate. I was assuming it had something to do with power steering?
Old Sep 21, 2010
  #49
rcelefano's Avatar
@Stipster, you should read the thread "How to diagnose your transmission". It sounds to me that the squeaking you're hearing, is not your throw out bearing but some type of clutch screw (don't quote me on that). If I'm right, just turn up the radio and ignore it.
If it is your throwout bearing, then when you push the clutch, a certain noise, should go away. Another thing is when you gear down, and release the clutch, you'll hear a loud noise, as if you're reversing (reversing noise).
@Olliemo, how's your steering fluid reservoir? Top'd up?
Old Sep 21, 2010
  #50
Kennykid2002's Avatar
Kenny the Ricer
Well, as we all know,
Honda engines were meant to last....
No one said anything about their transmission lasting :P
I guess ill make the switch to a Tc before i hit 100k miles on mines
Old Sep 23, 2010
  #51
Stipster's Avatar
yeah I already do just turn the radio up lol, it could also be my clutch pedal itself im hearing squeak but im not sure how I could grease it up or w/e, been to busy to even get my car in to the shop to get my front wheel bearings replaced as they are squealing like a pig
Also Just did the tranny diagnose, and I hear a quiet humming when the I have my foot off the clutch which that page says would be the input shaft bearing and to get it replaced
Old Jan 12, 2011
  #52
Olliemo's Avatar
haha wow yeah i looked and it needed to be added to. I did that right after you mentioned it. Thank you
ps. it fixed the problem for me!
moorebl
Aug 29, 2015 08:39 PM
CurryBomb
May 8, 2015 10:16 AM
smmahan
Apr 15, 2015 08:17 PM
silvervtec01
Dec 9, 2001 08:50 PM
TAZZ
Dec 5, 2001 09:35 PM
