please help out...
Old Dec 4, 2005
NOgoEM2's Avatar
-jdmWANNABE-
NOgoEM2 is an unknown quantity at this point
please help out...
if i missed a thread on this then im sorry guys...but i have been searching and reading up on people who have had overheating issues with their cars but im still not sure on the solution.....my car was fine until last night....i was just sitting in a parking lot with the car on but then i looked up and the temp gauge needle started to go up past normal....i then shut the car let it coll for about 20 minutes or so then i turn on to drive home as fast i could... but whats weird is as i was driving home...temp gauge was back to normal....i called some buddies and they told me to check for a leak....i did check and there was no leak...so could it be possible that i just need to add more coolant??? i have an 01 civic with 88k miles...any ideas? thanks guys and sorry if this subject has already been covered...
Old Dec 4, 2005
tacheon's Avatar
tacheon is on a distinguished road
Check to see if your radiator fans are turning on when you're experiencing an overheat. Its no surprise that the temperature drops the faster you drive for 2 reasons. First of all there is more air going through the radiator as the car moves, second the faster your engine is turning, the more coolant is pushed through the radiator. I'd be looking for an electrical problem of some sort with your cooling fans. Check fuse, temperature sensor, fan motors.
Old Dec 4, 2005
tacheon's Avatar
Also, ensure your coolant is at the correct level.
Old Dec 4, 2005
NOgoEM2's Avatar
-jdmWANNABE-
thanks for the imput Tacheon.....i checked the coolant fluid levels this morning and to no surprise...there was nothing left in the res. tank and when i opened up the radiator cap, no fluid .... so i just added some coolant temporarily until i get into work tomorrow and have one of my buddies do a coolant flush...thanks again!
Old Dec 4, 2005
streetglower's Avatar
you need to find out why you have no coolant. If there was none in the resovoir and none in the radiator, you have a leak somewhere. do a pressure test on the radiator and see if it holds pressure, if not look for a leak on the radiator, and also check your water pump and hoses really good. I would do all of this before you did a cooling flush, you dont want to put in new fluid if it will just leak in a day.
Old Dec 5, 2005
Blackpearl's Avatar
Blackpearl is an unknown quantity at this point
I hope you don't have a problem like gearbox! But better check out!
After the problem is solved, please report here what was the problem so other people can have usefull information in the future.
Old Dec 5, 2005
NOgoEM2's Avatar
-jdmWANNABE-
there aren't any leaks...okay this is what i think..i could be wrong but here goes..the reason i didn't have any coolant fluid left was because i've never had anyone do any type of coolant flush on my car since i got it...i got it brand new in 2001 and up until now i've never done anything with the coolant nor have i checked it...stupidity on my part....but again just to be on the safe side, i'm gonna do what you're saying streetglower....the last thing i need, seriously, is my only transport to be all **** up-ed.....thanks for the imput guys i'll update you guys as soon as I check this thing out.
Old Dec 5, 2005
Jrfish007's Avatar
Uhmmm... coolant doesn't just disapear, even if you never do anything with it. My dads Accord had the same coolant for 220,000 miles and never lost a drop.
Old Dec 5, 2005
NOgoEM2's Avatar
-jdmWANNABE-
jr you're right....coolant just doesnt disappear...today i had one of the techs check out my car at work and apparently there was still fluid in the car because when i added some yesterday it didnt take much at all to fill the radiator up to the neck...everything on my car seems to be fine for now..(knock on wood). He told me to just drive for a couple of days and see what happens because so far everything is back to normal..he also told me that it was most likely just an air bubble that went through the system but i probably already pushed it out...not his exact words but somewher around there...so hopefully everything is fine.
Old Dec 5, 2005
losing coolant but no visible leaks = welcome to my blown headgasket club! get a cooling pressure test done and you will know for sure. and air bubbles don't just happen unless there is a problem. you don't smell coolant inside the car do you? Try turning on the heater to full hot and listen for any kind of running water noise which would indicate bubbles in the heater core.
Old Dec 5, 2005
NOgoEM2's Avatar
-jdmWANNABE-
man...this is turning out bigger and worse than i expected...thanks for the tip gearbox...i'll check this out or atleast have another one of my friends whose a tech check this out for me...wtf man?! ever since i got this car, i've had nothing but issues...alright thanks again for the imput guys i'll have this checked out ASAP.
Adam925
Nov 19, 2019 10:56 AM
USCGBM
Aug 12, 2015 04:22 PM
Nikipedia
Jul 28, 2015 10:50 PM
Green02civic
Jul 27, 2015 10:48 PM
Pudnite
May 9, 2015 07:51 PM
