Speedometer help.
Old Nov 16, 2005
Goatboy's Avatar
Goatboy is an unknown quantity at this point
Question Speedometer help.
I need some help. My speedometer dose not work, until the car warms up. I talked to a honda tech, about the vss. He said if it is bad my odometer will go too. My odometer works fine. Any help appreciated.
Old Nov 16, 2005
Jrfish007's Avatar
He's right, if the vss sensor goes generally the odometer goes too. But since you have a digital odometer, that may not be the case. In any case, from here I can say ti could be a couple of things: loose wire, fualty guage cluster, bad sending unit, bad sensor, ect. The problem is that you will need to take everything apart and see where the signal is going bad. DO you notice anything else wrong with the car? Slight shaking when stopped at a red light or anything liek that?
Old Nov 16, 2005
Goatboy's Avatar
No other problems. I took the cluster out and checked for loose wires. It all looked good.
Old Nov 16, 2005
CraigW's Avatar
If the ODO is o.k. and the speedo not, my thinking is the cluster is getting the pulses from the speed sensor (same as VSS ??) You said you had it in and out, I was going to say to re-seat connectors.
Old Nov 16, 2005
Goatboy's Avatar
the strange thing is once the car warms up the speedo is fine.
Old Nov 16, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
I posted how to do a cluster diagnostic some time ago. Right now I have no idea how to find that post. If someone remembers it, please copy and paste it here. It lets you check the entire cluster including the comm line to the ecu.
Old Nov 16, 2005
Goatboy's Avatar
thanks will search for the post. If I need a new cluster, would you recommend swapping one with the stock tach. I have dx and thought about aftermarket tach.
Old Nov 17, 2005
tinman's Avatar
Stock tach is much cleaner. And it plugs right in.
Old Nov 17, 2005
Goatboy's Avatar
thanks guys for all the help. I will post the fix.
Old Nov 17, 2005
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
http://www.7thgencivic.com/forums/sh...hlight=cluster
Old Nov 17, 2005
tinman's Avatar
Yep, that's it. Thanks!
Old Nov 17, 2005
Goatboy's Avatar
I did the test, the speedometer is gone. I appreciate every bodys help.
Crazygrlinak
Oct 8, 2015 05:06 PM
ken4444
Sep 30, 2015 07:37 PM
juicetayne
Sep 30, 2015 11:02 AM
Islesfan
Sep 29, 2015 03:42 AM
260000milesgoal
Sep 25, 2015 07:41 PM
