Headlight problems (drivers side does not work) - No.. Not a recall, please help ASAP
Old Oct 14, 2005
p5hnganthrday's Avatar
p5hnganthrday has a little shameless behaviour in the past
Alright...
Passenger headlight works fine
Driver side headlight does not
Before you start saying, "recall, recall", no... My car was not issued a recall,
I searched many times and its funny how everyone always mentions recall right away and they dont even tell you what to do...
I guess ill be the first... Check out,
https://www.ahm-ownerlink.com/login.asp
If you dont have an account make one, sign in, click "recalls" and enter you VIN#, and it will TELL YOU, if there is a recall for your car.
BACK TO TOPIC
No.. Its not because of high wattage bulbs...
As mentioned...
Passenger side headlight works... Drivers side does not.
The odd thing is...
Passenger Headlight AND foglight works... Drivers side headlight AND foglight DO NOT WORK
So... I' am thinking its a problem with the headlight harness? Anyone have ideas? Some people mentioned it had to do with fuses? Well, engine bay fuses are fine...
Someone mentioned something about curcuit work going bad or something?
Anyways, I' am in need of help because Its very hard to drive around my area with just 1 headlight and I drive for literally 80 minutes/night and I definatley dont want a ticket. So, any information would be great.
Old Oct 14, 2005
streetglower's Avatar
well the first thing to do is check to see if the bulbs are burnt out. You dont understand how many times customers use to come in and say they were having issues because half of there light bulbs in the car didnt work. And it ended up being burnt out bulbs. I replaced 6 bulbs on this one ladies car one time. SO check the bulb first.
Next if the fuse looks ok, doesnt mean it is ok. You need to physically make sure power is going though it. fuses can look good and be bad.
You also have a relay for both the driver and passenger headlight. Its possible that the relay failed.
But the best thing would be to check for power to the headlight. Also does the high beam work for the driver side headlight?
Old Oct 14, 2005
Bulbs are fine...
Ill swap out the left headlight fuse tomorrow to see if it is the fuse...
Usually you can tell if a fuse is broken (hopefully in this case i cant)
where is the relay located? and how much is that? Would I be able to DIY it?
Old Oct 14, 2005
CraigW's Avatar
I have some wiring info if you want it. PM with E-Mail. What year and body style ?
Old Oct 14, 2005
the relay is located in the under hood fuse box. There is a test procedure to test it. it involves applying power and ground to pin 3 and 4 and seeing if there is continuity between pins 1 and 2. there should be. And there should be no continuity between 1 and 2 when power is disconnected from 3 and 4.
And yes I should have also asked what year. the 04-05's headlights circuit is different then 01-03.
Old Oct 14, 2005
2002 EX Coupe (auto)
Old Feb 23, 2007
Tokoyama's Avatar
Tokoyama is an unknown quantity at this point
talk about brining a dead thread back to life, but i seems that i am having very similar problems. i just rewired my gauge cluster wire connector to swap a 03-05 cluster into my 05 VP and that worked out fine, BUT, heres the issues im having with my headlights now:
When i turn on lowbeams:
- only passenger side turns on
- Driver side highbeam comes on
when i turn on highbeams:
- Only passenger highbeam comes on
i checked the bulbs to see if maybe my driver side burned out, i swapped the passenger side with the driver side, and theyre both working on the passenger side. anyone have any ideas what could have happened? sorry for bringing this thread back up i just really need the help
MN-02-CivicEx
28
May 2, 2015 09:11 PM
shaejb15
Apr 26, 2015 07:44 PM
ej8
Apr 13, 2015 06:36 PM
mwwhonda
Nov 7, 2001 07:24 PM
EXWisdom
Nov 5, 2001 10:24 PM
