Headlight Problem
Old Feb 23, 2007
Tokoyama's Avatar
Tokoyama is an unknown quantity at this point
Headlight Problem
so i just rewired my gauge cluster harness to swap a 03-05 cluster to a 05 VP, and everything went fine, but as i went on testing everything i noticed that when i turn on my headlights, only the right headlight turns on and the left highbeam comes on. i checked the bulbs to see if the left lowbeam burned out, but its working fine. also when i turn the highbeams on the left highbeam turns off and only the right highbeam goes on. the hecks going on?
Old Feb 23, 2007
wontonamo's Avatar
wontonamo is an unknown quantity at this point
if its not your bulbs, you might have a shortage somewhere
Old Feb 23, 2007
Tokoyama's Avatar
do you know what i can do to fix it?
Old Feb 23, 2007
CraigW's Avatar
The only line that should be coming to the cluster dealing with the headlights circuit would be for the "high beam indicator"
Check its location to see if correct, Take it loose to see if the headlights work normal.
Old Feb 23, 2007
Tokoyama's Avatar
turned out to just be a blown fuse, already replaced, working fine now, cept now my radio isnt turning on -_-, ill do searches for that
stryder12
Jun 30, 2015 08:33 PM
carid
Jun 5, 2015 11:51 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
intensity
May 12, 2015 10:43 PM
shaejb15
Apr 26, 2015 07:44 PM
