Blinker
Old Sep 9, 2005
MVHonda's Avatar
MVHonda is an unknown quantity at this point
Blinker
Hey people,
Our Blinker/Hazzards have gone out. For some reason they still light up but they don't work (blink) when you try them. Any help?
Thanks all.
MV
Old Sep 9, 2005
CraigW's Avatar
How about the turn signals ?? What year ??
Old Sep 9, 2005
notoriouspyro's Avatar
Crack kills... But then again... So do I...
notoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the rough
Hmmm... wonder if you blew the control fuse.... Never heard of that happening, but I guess there's a first to everything...
Old Sep 9, 2005
MVHonda's Avatar
oh, i wasn't clear, yeah, they are the turn signals and I have checked the fuses, they are fine.
2001, sorry, I forgot it's 7thgencivic.com, I joined when it was 2k1civic.com years ago.
Old Sep 9, 2005
streetglower's Avatar
do the lights not flash with either the headlight switch and the hazard button?
Old Sep 9, 2005
MVHonda's Avatar
neither time but the lights do work though. that is the weird thing. I am thinking it may be in the actual steering wheel but that wouldn't explain the hazards also not working. Is there a relay or something?
Old Sep 9, 2005
yes there is a relay and I would suspect that if neither are flashing. You can physically check the relay or buy another one. If you have a Multimeter, let me know and I will tell you how to check the relay.
Old Sep 9, 2005
MVHonda's Avatar
don't have one but where would I find it? Under the hood?
Old Sep 9, 2005
the relay is underneath the dash in the under dash fuse box.
Old Sep 9, 2005
MVHonda's Avatar
great, Thanks for all of your help.
Old Sep 9, 2005
CraigW's Avatar
I have the wiring info from an 01 on this circuit if you need it pm with E-Mail.
It is called a "TURN SIGNAL/HAZARD RELAY" on the sheet I have.
Could well be the problem.
Old Sep 9, 2005
MVHonda's Avatar
yes, because I just got home and can't find it worth a damn.
Old Sep 9, 2005
MVHonda's Avatar
well if it is where i think it is, then its under the steering wheel but tucked way towards the center console and extremely hard to get to. am i right? if so, is there an easier way to get there?
Old Sep 9, 2005
it is underneath the steering wheel in the dash fuse box. Just remove the dash piece under the steering wheel by loosening those 2 plastic screws and look on the diagram for it. It is the relay on the right side of the fuse box. should be easy to get.
Old Sep 9, 2005
MVHonda's Avatar
It's behind some heavy wire and yes, I guess we are looking at the same thing.
Old Sep 10, 2005
there are only 4 relays in the dash fuse box. The starter cut relay, power window relay, turn signal/hazard relay and the taillight relay. The turn signal/hazard relay is the largest relay in there. The one farthest to the right of the box.
jtdunn4life
Oct 27, 2015 03:33 AM
profurious
Feb 10, 2003 12:48 PM
FlippedOut
Jan 30, 2003 08:40 AM
slikor
Dec 3, 2002 12:22 AM
pbEnjeN
Aug 22, 2002 01:36 AM
