headlight wire connector
Old Aug 28, 2005
ItalianCivic77's Avatar
ItalianCivic77 is an unknown quantity at this point
So basically the dealership told me that my socalled "aftermarket" headlights that I got from Murrays caused this. The actual connector to the bulb for my low beams is fried. Like really fried, I was wondering if anyone had an extra connector or knew where I could just buy the connector. The dealership wants to charge me like $300 for the whole wire system for my lowbeams. I really only need to just splice in a new connector. Someone please come to my rescue! Thanks
Old Aug 28, 2005
ohnoitssoysauce's Avatar
ohnoitssoysauce is an unknown quantity at this point
i need the same thing cuz i cut mine when i installed my projectors. now i wanna go back to stock but i need the wires
Old Aug 28, 2005
Nick's Avatar
Formerly 2blu
what king of lights??
Old Aug 29, 2005
streetglower's Avatar
http://www.hondaautomotiveparts.com/...RS+%28FRONT%29
the new connecter should come with a few inches of wiring on it so you can splice it into the existing wiring.
Old Aug 29, 2005
blouisgod's Avatar
Life Begins > 6800rpms
those connectors were recalled on my 2001. check into that, they may be covered by honda.
Old Aug 29, 2005
Da1lyDr1ver's Avatar
^^^ he's right, the wire harnesses for the '01-'03 civics were recalled about 2 years ago. you should look into the TSB for it. also, make sure if you buy aftermarket bulbs (hyperwhites, etc.) you match the wattage. i think stock wattage for our low beams is 45w, but most hyperwhites and stuff have higher ratings, like 75w. if thats the case then it will burn up your stock wire harness.
this happened to my sister's sentra. i just swapped the stock headlight bulbs back in and they fixed it with a heavy duty wire harness. if i didnt swap the bulbs she would probably have to pay for the fix...
Old Aug 29, 2005
so on that site, is 9 and 10 all we need for the headlights to work? lows, highs, signals and everything?
Old Aug 29, 2005
#9 is the headlight connecter you need assuming that is the only one you fried. and assuming the rest of the wiring is ok. One thing you can do is turn on the headlights and see if you have 12 volts going to the connecter. If you do then replace that connecter. If you dont have 12 volts going to it, better check into the rest of the wiring.
Old Aug 29, 2005
ok thank you so much!!
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Blazz
May 25, 2015 10:56 PM
shaejb15
Apr 26, 2015 07:44 PM
NukeSilo
Nov 4, 2001 09:37 PM
