Simple light Problem, But still can't figure it out..
Old Aug 18, 2005
mz04zf's Avatar
mz04zf is an unknown quantity at this point
I installed the halo projector lights into my 2004 civic lx and sure enough, 1 month later a bulb blew. I replaced the bulb and it works but only for a while. It will work but soon after it goes out so i have to open my hood and flick it back on. When i take the bulb/wire out and touch it to metal it remains on but does not remain on by itself. The bulb is connected properly and is inserted the right way. Please help, it is becoming a constant problem!!
Old Aug 18, 2005
streetglower's Avatar
what do you mean by when you pull the bulb and wires out of the headlight and touch it to metal it will remain on, but not remain on by itself?
Old Aug 19, 2005
mz04zf's Avatar
I mean when the blub is attached to the wire it should be on, but its not. It only comes on when you touch the frame of the bulb to something metal.
Old Aug 19, 2005
CraigW's Avatar
Have you checked the ground lead and the ground connection in the plug for the bulb ??
CarStuff
Dec 6, 2020 12:52 PM
rcolosi
Apr 29, 2015 07:48 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
meels808
Nov 16, 2001 11:18 AM
