Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Old Jun 26, 2011
  #31
wade623's Avatar
wade623 is an unknown quantity at this point
Re: Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Originally Posted by DiLMar
I have this message from my check engine light on :
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
I guess I need to change my O2 sensor which is something that I could do myself. But could anyone help me which O2 sensor I need to buy exactly??? I have a 2005 Honda Civic Coupe VP. Thanks in advance!
that could mean that the sensor is not plugged in or there is a short in the wire somewhere bank 1 sensor 1 you can see it as soon as you open the hood it is the thing sticking out of the exhaust with 4 wires coming out of it
Old Sep 9, 2011
  #32
wingsfan19's Avatar
wingsfan19 is an unknown quantity at this point
Re: If You Are Having Car Problems And Your Check Engine Light Is On, Please Read Thi
Autozone and O'reilly will check your codes and give you the print out for free.
Old Oct 18, 2012
  #33
AFistFull's Avatar
2005 Honda Civic LX-G
AFistFull is an unknown quantity at this point
I have just fixed, reset my SRS light. My code read
9-3 Faulty driver’s seat belt buckle switch.
Seems to be a common problem.
This guy help from his website. Thought it might be useful.
h ttp://www.vehix411.com/category/honda-airbag
Old Oct 18, 2012
  #34
AFistFull's Avatar
nice
Old May 3, 2013
  #35
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Originally Posted by Camo
I HAVE A 01 EX and just changed converter and o2 sensors and egr valve and getting P0141 CODE any sugestions would be great
could be a short in your ground, or wiring issue.
Repair short or open or high resistance in wiring harness or harness connectors
Verify battery voltage to the rear O2 sensor heater on the Black/Yellow wire with the key on. Check the Rear O2 sensor heater ground circuit voltage to the computer on the Black/White wire; clear the code first and see if the computer ever tries grounding the Black/White wire when starting the engine and if the code resets. Depending on what you find you will need to fix conector or repair/replace wiring.
P0141 Heated Oxygen Sensor (Bank 1 Sensor 2) Heater Circuit Malfunction
Possible CausesSetting Conditions
  • HO2S connector is damaged (check the fuse t o the heater circuit for damage, and for moisture)
  • HO2S heater power (12v) circuit is open (check the fuse to the heater circuit)
  • HO2S heater ground circuit is open
  • HO2S heater has failed
  • PCM has failed
Old May 4, 2013
  #36
Measure the resistance of the heater circuit on your new sensor (rear sensor).
Spec is 10-40 ohms.
My guess: Throw away the Bosch sensor. Get a correct DENSO sensor.
Old Sep 6, 2013
  #37
UNKNOWN414's Avatar
UNKNOWN414 is an unknown quantity at this point
I had some electrical issues on my car so I dismissed the check engine light coming on as something tied to a funky fuse or something of that nature. I got sick of looking at the darn light after a while so I found a nice low price OBD II scanner that works right with your android phone at a fraction of the cost of some of the more expensive brands. Found the code was tied to something completely different (but a cheap fix thankfully) The scanner I tried was from www.bafxpro.com, the bluetooth model.
Old Apr 11, 2016
  #38
mapdog's Avatar
mapdog will become famous soon enough
My SRS light came on when the alternator was producing too much current. New alternator = no light.
PS, the dealership couldn't get any codes at all for any system.
Old Apr 11, 2016
  #39
True, this particular problem leaves no fault codes.
Old Jun 14, 2016
  #40
dweesb's Avatar
dweesb is an unknown quantity at this point
2 part question... I've tried to reset the SRS light myself several tries with no luck. The light cycles on and off like the directions describe, but only the first two times. During the third ign. on/off, disconnect/reconnect my leads the light stays on. Does this mean anything to anyone? I had the light reset at my local shop when I first got the car to get my inspection sticker.
Second... With regards to reading the OBD codes, which light is blinking that I'm supposed to be counting? The SRS light or the check engine light?
Thanks all
Old Jun 14, 2016
  #41
mapdog's Avatar
My SRS light stayed on when the alternator was bad and overpowering the circuit.
Old Jun 14, 2016
  #42
dweesb's Avatar
Thanks, I'll check that
Old Jun 14, 2016
  #43
Thanks all
If you are looking for engine codes, count the blinking engine light.
If you are looking for SRS codes, count the blinking SRS light.
Old Jun 14, 2016
  #44
dweesb's Avatar
Thanks for clarifying
Old Jun 14, 2016
  #45
dweesb's Avatar
I just remember.,. When trying to rest the SRS light, while it doesn't cycle on and off on the third ign on/off, the engine light will blink twice. The SRS light stays on,
but the engine light stays off.
Old Nov 18, 2017
  #46
BillLit's Avatar
BillLit is an unknown quantity at this point
Followed your thread SRS and engine light off now for abs just bought the car thank very mucb
Old Jun 13, 2019
  #47
Matthew Sheets's Avatar
Matthew Sheets is an unknown quantity at this point
What would make it that my SRS light doesnt come on at all, and how to fix? Any help?
Old Jun 14, 2019
  #48
BrotatoChip's Avatar
Super Moderator
The bulb/LED being burnt out. Doesn't come on at all when the key is first turned on?
fivebells
Aug 12, 2014 11:34 AM
streetglower
Electronics DIY
82
Sep 7, 2013 07:05 PM
Justinsn95
Dec 19, 2009 08:59 AM
ackos
Apr 8, 2005 01:02 AM
Weathered
Mar 13, 2004 01:06 PM
