Jumped the gun on resetting the SRS light. Can I still get any related diagnostics?
Old Aug 11, 2014
fivebells's Avatar
fivebells is an unknown quantity at this point
The SRS light on my 2002 Honda Civic came on and stayed on recently. I found some claims online that this is a common failure, and it suffices to simply reset it, which I did as described in the sticky thread here. Then I learned about the diagnostic codes, and I wonder whether I've lost the opportunity to find out exactly why the light came on.
The light has not come back on since I reset it (apart from the tell-tale flash at ignition time.) If there are any diagnostics for the system to report, should I still be able to get them out?
Old Aug 11, 2014
Poopies's Avatar
Super Moderator
Re: Jumped the gun on resetting the SRS light. Can I still get any related diagnosti
Yeah, if you have a reader you should still be able to get them. If they're cleared out and the problem persists, the light will probably come on after a few on/off cycles.
Old Aug 11, 2014
IF codes and memory were erased by using the jumper wire in the MES connector in the fusebox, all pertinent data is gone.
You will have to wait until the failure and light returns to get the info you want.
If the light simply went out on its own, the data may still be in memory for some period of time.
Old Aug 12, 2014
fivebells's Avatar
Thanks, folks. I'll wait and see if it comes back on, I guess.
SimpleUser
Apr 24, 2021 02:54 AM
mjdiaz89
Jun 21, 2016 09:26 PM
jzhartman
22
Jul 23, 2015 10:42 PM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
