Trunk Lock
Old Apr 9, 2005
PennyKnotOff's Avatar
Trunk Lock
My trunk lock, the one next to the drivers seat, doesn't work. I don't know what or even if it ever worked but I was trying to lock it last night and it wouldn't lock. Your supposed to be able to lock it so that the only way to open it is to have the key right? But if I lock mine all you have to do is pull the latch. I did some searching and didn't come up w/ anything. My car is an 01 LX Coupe. Any help is appreciated.
Old Apr 9, 2005
CraigW's Avatar
Sorry, Have to ask. You are not by chance using the valet key ?? Does the key turn at all ? Are you turning it all the way until it clicks ??
Old Apr 9, 2005
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
Check out the lock rod. It may have gotten loose. There is also a TSB for this issue.
http://www.geocities.com/pfeifferper...oesNotWork.pdf
Old Apr 9, 2005
I actually maybe be using the valet key. Ill check it out thanx for the info.
fvckbg
Oct 20, 2016 07:37 PM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
aaronmechanx
Sep 14, 2015 08:45 PM
First Car
Sep 8, 2015 08:54 PM
