Transmission slipping - automatic
Old Aug 14, 2004
  #31
Usually, holding down the brake while pressing the gas will do in the torque converter. Neutral drops just mess up the gears.
Old Oct 19, 2004
  #32
vtecman04's Avatar
vtecman04 is an unknown quantity at this point
yeah they will, but what's his name asked if u could drop from D to neutral on auto's, i do that all the time nowadays but i'm scared about messin nethin up, the only thing that could be bad is the stress on the gear tips/ends (wut ever u call them) while they are being lifted...
+ is it ok to put it back into D from neutral when the car is still moving like 5-10 miles an hour, <- once again IMO, if the rpm's are lower than 1K then its ok,
feel free to correct me if i'm wrong, i'm just using logic!!!
Old Oct 19, 2004
  #33
I would not switch gears unless the car is stopped. Very slow movement like idle would be okay prolly.
Old Oct 19, 2004
  #34
andwong's Avatar
andwong is an unknown quantity at this point
Is there a filter inside the Trans, if so, do we need to change the filter ?
Any DIY step by step process map.
Old Oct 19, 2004
  #35
There is no way to change the filter, as it is inside the tranny. Only thing you can do is wipe off the shavings that collect on the magnet plug when you drain and refill the fluid.
Old Oct 22, 2004
  #36
vtecman04's Avatar
mmmmm, negative, i think that it wouldnt hurt my vic, i mean because of doing thatk, i got an extra 32 miles ... plus doesnt the transmission itself keep rotating a little + when the engine rpm is less than 1k, come to think of it, it also has the same effect when the auto trannny is swithing gears, so i bet it knows how to manage it.
FutureCivicOwnr
Aug 11, 2015 10:59 PM
Smokahontas123
Jul 22, 2015 10:07 PM
Q-Bert
Jul 19, 2015 09:09 PM
Jul 12, 2015 11:54 AM
fatih717171
Jul 8, 2015 12:14 AM
