Problems with my Gauge Cluster Needle Lights? Help
Old Jul 27, 2004
streetglower's Avatar
Arrow Problems with my Gauge Cluster Needle Lights? Help
Well I went to walmart tonight and right as I turned on my lights, my gauge lights came on as normal. But after a few seconds, the needle light for the fuel gauge went out. I tapped the plastic and it came back on, but went out again for good. Now also the needle light for the speedometer also went out. But half of it stays on while half of it is out. While I am at idle the speedometer needle light will stay on, but when I am driving, half the light goes out, and then when I hit 60 mph and above it comes fully on. Both needle lights for the tachometer and engine temp gaige work fine, but these 2 dont. I have indiglo gauges and they work fine, it is just the 2 needles. Anyone know the problem and how to fix it? Also to fix it does the gauge cluster need to come out? Also do you think I should take it back to the place who installed the indiglo gauges or take it to the dealer or a shop to have them check it out?
Old Jul 28, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Take out the cluster and change the bulbs. Or make sure the bulbs are snug in the sockets and that THEY are properly seated.
Very simple. 15 min. tops.
Old Jul 28, 2004
cool, thanks, I am about to take it to the shop that did it.
Old Jul 28, 2004
does anybody think it would have to do with the wiring? or just the bulbs going out. Because if the bulb was going out or is out, wouldnt the hole needle light not work. The fuel needle light is out, but the speedometer needle is half lit and changes when I drive. I cant go to the shop for a bit, but was just curious.
Old Aug 1, 2004
ELaudio's Avatar
ELaudio is an unknown quantity at this point
Those bulbs are flimsy as hell. What probably happened is the filament broke, and the contact was intermittent. Yup - change the bulbs and you should be all good.
Old Aug 1, 2004
There are five backlight bulbs for the cluster that light up the numbers AND needles using light guides. If you take off the indiglos, you'll see that parts of the gauge face are also not lit up. Just check the bulbs in the back.
Old Aug 1, 2004
I will do this sooner or later, as of now I am very lazy to do it. Thanks for the help.
Old Aug 10, 2004
2K1Civic17"Gabe's Avatar
if you have indiglos, they could be hooked up wrong, I had mine tapped to the wrong wire due to no instructions, and when I found some instructions, they went back on. It could be the wrong wire. Make sure they tapped the red/black one I believe, and grounded the black
Old Aug 10, 2004
Well the indiglos come on, it is just the needle lights. only 2 of them are way dim. I am not too worried about it anymore though.
trellex
May 24, 2015 04:39 PM
Ma213802
May 18, 2015 07:01 AM
werdnahall
May 17, 2015 11:37 AM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
