Suspension Pop
Old Jul 26, 2004
ponyman's Avatar
ponyman is on a distinguished road
Suspension Pop
Okay so here is a wierd one....If I let my car sit for awhile (long enough to completely settle) and then drive I get a wierd binding/clanking/clicking/popping noise when if first touch the brakes (only on a light touch and not a full brake press)...what the heck is this??? I mean is it a brake issue, or is it a suspension issue? I have no idea...Anyone else have this weird noise????
Old Jul 27, 2004
streetglower's Avatar
so when you let your car sit for awhile and then start to drive, does this happen right when you go to break for the first time? If so either your rotors are warped and need to be turned or replaced, or you need to check your drums. They might be warped too. I had the same problem and replaced my rotors and drums and it went away.
Old Jul 27, 2004
ponyman's Avatar
no ****....huh, that is funny since i am like the easiest person on brakes that I know....hmmm, warped rotor after 20K miles, yeah i don't think i'm gonna be the one paying for this....thanks streetglower, i guess that i will call honda today....
Old Jul 27, 2004
no problem
Old Jul 27, 2004
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
Front or rear? The front pads are known to click if you reverse and hit them, then drive forward and hit them again. If it is the rear, the shoes might be out of adjustment and you're hearing the springs. My right rear was out of adjustment at 23k and made noise until I fixed it. Self-adjusting my A$$.
Old Jul 27, 2004
ponyman's Avatar
they are the fronts
Old Jul 27, 2004
Sickboy's Avatar
It happens every time you lightly touch the brakes, or only once the first time you touch your brakes?
Old Jul 27, 2004
he said the first time he touches his brakes.
Old Jul 27, 2004
Sickboy's Avatar
"I get a wierd binding/clanking/clicking/popping noise when if first touch the brakes"
It's probably just the brake pads clicking as they reposition themselves, mine do this every morning. If it's when he lightly touches the brakes he needs his rotors turned.
Old Jul 27, 2004
Mine never do that. Mine work there best the first few times I stop. Most likely your rotors are warped. or your drums are warped. you shouldnt have those kinds of noises at all. It isnt normal. when mine started doing that only the first time I used my brakes, I took it in right away and they found the drums to be extremely gone.
Old Jul 27, 2004
Sickboy's Avatar
You have aftermarket pads, so no clicking. If he's only hearing noise once, when he first hits his brakes, I doubt its the rotors or drums.
Old Jul 27, 2004
yes I have hawk pads and brembo blanks. if you are getting all sorts of shitty noises the first time you break, most likely it is your rotors or drums. Just to make sure, have them looked at. Have a shop get the specs on the rotors and drums and have them check the pads as well.
Old Jul 27, 2004
Da1lyDr1ver's Avatar
if you still have the oem brake pads, then its your front brake pads shifting when you step on the brakes for the first time. if you're not sure then try this: reverse the car and let it roll a little bit and step on the brakes for a complete stop. then go forward and step on the brakes for a complete stop. if you hear a pop or a click, then its your front pads. its totally normal for this to happen, especially on your honda. try this, its better than replacing parts that are still good.
Old Jul 27, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Stock pads don't fit in the stock caliper too well... go figure. It seems to go away when they're changed for ANY aftermarket ones... so its a simple solution.
Old Jul 27, 2004
I never thought of that. Most of the time with these noises, it has always been my rotors or drums. I would think honda parts would fit better than any parts, but I guess I am wrong.
Tedverseti
Apr 23, 2020 01:45 PM
ricer_em2
May 11, 2016 08:09 PM
sesi
Oct 1, 2015 02:03 PM
Tedverseti
Sep 29, 2015 05:41 PM
czarlun
Sep 14, 2015 08:16 PM
