Problem with indiglo needles.
Old Jul 26, 2004
prcivicblue's Avatar
prcivicblue is an unknown quantity at this point
I change my gauge to indiglo, but when I finished the needles don't run. I verify again and nothing is touching the needles or getting stuck. I need to calibrate the needles? Only the RPM and the MPH. Pls let me know.
Old Jul 26, 2004
Make sure that the needles are moving freely with your finger, but unplug the cluster first. It should not be rubbing anything. Alot of times the gauge face is loose or not taped on enough. If you didn't remove the needles, then they're probably just getting stuck. You can even try to pull them out slightly, but more than likely the gauges you installed are not taped down enough.
Old Jul 26, 2004
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
nothing much more to say thanks to gearbox but mine do get stuck sometimes on the covers but i just tap the outside of them gauge cluster and they are fine.
Injen
Old Jul 26, 2004
clownprince's Avatar
Ricerus Maximus
make sure they're plugged in, sounds kinda stupid but i got a friend that forgot to plug his back in.
Old Jul 26, 2004
ponyman's Avatar
ponyman is on a distinguished road
I had a similar problem when I put them on my 01...as it turned out...there is a little retainer type clip underneath the center of the needle that came up...if you look under ther and see a hole as opposed to the lip of the clip then that is probably your problem
Old Jul 27, 2004
Thks to all. I put some tape and glue to the back of the indiglo. The problem was that it pop-out and the needle get stock-still/
Thnks every one for the help.
Old Jul 27, 2004
D5cIvIc's Avatar
you shouldn't use glue to put that on there i don't think. just use some SCOTCH thin double sided tape and it will do u fine. but glue is no good man..
Aznnp77
Jan 6, 2002 08:41 PM
LX2slow
Dec 20, 2001 08:33 AM
manicEL
Dec 10, 2001 06:33 PM
AJ
Dec 4, 2001 09:08 PM
GreenVenom
Nov 13, 2001 03:35 PM
